Author Topic: Rear brakes anti rattle shims  (Read 5794 times)
laney101
  • liverpool
    • omega elite v6
« on: 05 July 2017, 06:23:17 »
Fitted new discs and pads to rear of my 3.2 omega however the rattle shims had badly corroded so new ones needed..
Ive ordered three pairs up to now and all been wrong anyine else had this issue.. All three sets were different length pins but all to short and rattle shims didnt quite fit
Struggling now can anyone help
JDX
  • Hersham, Surrey.
    • '02 2.2dti CDX estate.
Re: Rear brakes anti rattle shims
« Reply #1 on: 05 July 2017, 07:13:37 »
Where did you order them from?
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #2 on: 05 July 2017, 07:27:04 »
anti rattle shims go between the piston and pad?
e46 325i se - 1.8vvti avensis liftback
JDX
  • Hersham, Surrey.
« Reply #3 on: 05 July 2017, 07:35:58 »
Oh, I was thinking about the clips that look a bit like a cross that fit over the outer edge of the pads  :-[
frostbite
    • 00' e46 325i se
« Reply #4 on: 05 July 2017, 07:39:45 »
I think their called spring clips
There is an FAQ on the rear brake fitting kits, has the part numbers for the vented calipers
EDIT:
http://www.omegaowners.com/forum/index.php?topic=127928.msg1811725#new
JDX
  • Hersham, Surrey.
« Reply #5 on: 05 July 2017, 07:42:21 »
....they're retaining clips or springs.
Vauxhall used to do a kit - I remember buying it when I first got my car but that was a long time ago now!  :)
JDX
  • Hersham, Surrey.
« Reply #6 on: 05 July 2017, 07:46:10 »
Just seen....brilliant! :y :y
« Reply #7 on: 05 July 2017, 08:16:04 »
The spring clip from the solid disc set is fine, just clean up and reuse the pins :y
« Reply #8 on: 05 July 2017, 08:43:01 »
Not so, it can jam between the pads... Effectively locking out the rear brakes.
« Reply #9 on: 05 July 2017, 17:59:05 »
Wot he says.
New pins and spring available from dealer still, but from memory the pins are something like £4 each :o
laney101
  • liverpool
    • omega elite v6
« Reply #10 on: 05 July 2017, 18:44:43 »
Checked with dealer no longer avalable pins and clips (I meant the cross clip apologies ) all sets I had are way to short
« Reply #11 on: 05 July 2017, 19:09:47 »
Try a different dealer, just in case.  Some seem to suffer CBA.
« Reply #12 on: 05 July 2017, 20:30:57 »
Apologies, I thought they were the same. I've always just reused, even if I have to repair them
laney101
  • liverpool
    • omega elite v6
« Reply #13 on: 07 July 2017, 16:11:36 »
they are no longer available (as a kit )
however you can purchase each piece individually what a joke haha .....
no new ones ordered
« Reply #14 on: 07 July 2017, 16:37:20 »
no new ones ordered
This was the reality five years ago... complete set was around £40 last time I bought any.
