Author Topic: This could be a challenge.  (Read 9405 times)
shyboy
  • Southport, merseyside.
    • Mazda 6
« on: 08 July 2017, 07:30:15 »
I've finally bitten the bullet and decided to change the 3.2l cambelt etc. myself, in spite of old age, associated aches and pains, and not having done it before. I bought the excellent CD years ago.
Just ordered a Contitech kit and trying to find a suitable water pump as an alternative to the main dealer quoted price of C.£180.
There are quite a number of low priced alternatives on-line; (£25/£35) and a Bosch version at around £95. Anybody got experience of the quality of these, or a suggestion as to one which would do the job satisfactorily.
Please expect to see follow up posts crying for help. >:(
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: This could be a challenge.
« Reply #1 on: 08 July 2017, 08:53:09 »
I believe that some pumps have plastic blades and that these are the ones to avoid.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 08 July 2017, 09:29:27 »
Does your car need a new pump ?
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #3 on: 08 July 2017, 09:34:55 »
They say that old men need a hobby that makes them think and use their hands, otherwise they fade away and die. Congratulations in taking on the cam belt change job.
 Forum opinion on changing the water pump on V6 engines is changing, 'cos it is not driven by the cam belt, unlike the 4 cylinder engine. If it fails, it will not wreck the engine, just need changing, which will admittedly involves much of the same dismantling.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 08 July 2017, 09:47:52 »
Whaler is I believe a good make The one I fitted had the GM insignia ground off so I assume they supply GM.
shyboy
    • Mazda 6
« Reply #5 on: 08 July 2017, 10:59:24 »
Thanks for your replies, and the encouragement Terry P.
I don't think the pump is problematic but thought it might be prudent to change it when doing the cambelt, if the cost is sensible, in view of the dismantling necessary if it should fail. As it isn't cambelt driven, failure obviously wouldn't be an out and out catastrophe so I'll probably not bother if it looks in good condition when I examine things more closely.
Robson. I can't find your Whaler pump. Did you mean Whale? and do they do automobile pumps?
Thanks again.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #6 on: 08 July 2017, 11:06:22 »
As far as i can remember .someone please correct me if im wrong here but can you not change the waterpimp on a v6 without taking anything off the engine at all? Just the bagpipes for acess.i seem to remember the bolts are all easy to get at once its pulley is off ?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 08 July 2017, 11:08:37 »
 Wahler I thought I might have spelt it wrong I will check and come back to you.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 08 July 2017, 11:11:26 »
Yes it is Wahler
shyboy
    • Mazda 6
« Reply #9 on: 08 July 2017, 11:45:20 »
Thanks Robson. Their US site doesn't list Opel, Vauxhall or Opel believe it or not. Can you remember how you found your pump?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 08 July 2017, 12:01:14 »
I think you will find that the CD shows twin adjustable tensioners, whereas the later kits only have the one. Still a very useful guide though. :y
shyboy
    • Mazda 6
« Reply #11 on: 08 July 2017, 13:37:16 »
Hopefully I'll be able to allow for that. If not, watch this space!  ;D
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #12 on: 08 July 2017, 13:46:32 »
James did my 2.6 cambelt for me whilst I watched, and he said that if the pump is original (it was) and feels ok, thenleave it, as pattern and even genuine Vx are not as good nowadays.
He lubricated the bearings, span the pump and it sounded great.
I hope the Fates aren't listening when I say that it is still fine!
Go thou and do likewise.....
Ron.
Migv6 le Frog Fan
« Reply #13 on: 08 July 2017, 14:17:49 »
10 years ago when VX charged £20 odd quid for a V6 water pump it was thought sensible to bung a new one in while the front of the engine was dismantled.
Now they are silyl money, and possibly not as good quality, the accepted wisdom is "if it isn't broke, don't fix it".  :y
Bigron
  • Witham, Essex
« Reply #14 on: 08 July 2017, 14:28:50 »
Silly money and low quality, Albs - we are on the same page here.  :y
Ron.
