Author Topic: Steering Idler  (Read 13269 times)
LC0112G
Steering Idler
« on: 19 July 2017, 10:20:16 »
Just had MOT, advisory on the steering Idler P/N 9195731.
Went to Vauxhall this morning, and it's NLS. Tried to order it from Autovaux - nope no genuine OEM stock.
So where are we at now? Febi, Lemforder?
Re: Steering Idler
« Reply #1 on: 19 July 2017, 10:49:01 »
IIRC someone (serek, maybe?) had a source of a poly version..
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
Re: Steering Idler
« Reply #2 on: 19 July 2017, 19:58:11 »
Rubbish, I got one about 3 weeks ago from Vauxhall.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Steering Idler
« Reply #3 on: 19 July 2017, 21:30:31 »
I had a febi one off ebay, had the part numbers cast into the arm
so supposedly a good one, 110mm iirc
e46 325i se - 1.8vvti avensis liftback
LC0112G
Re: Steering Idler
« Reply #4 on: 19 July 2017, 22:39:00 »
No UK or Europe stock. No dealer search stock showing either. If Andy Clears is about perhaps he can confirm?
LC0112G
Re: Steering Idler
« Reply #5 on: 19 July 2017, 22:40:14 »
The arm isn't the problem - it's the bush/bearing.
Re: Steering Idler
« Reply #6 on: 19 July 2017, 23:32:29 »
I used to nip mine up now and again when it seemed a little slack.  :-X  ;)
frostbite
    • 00' e46 325i se
Re: Steering Idler
« Reply #7 on: 20 July 2017, 07:18:23 »
It cost £8 with free postage, about 2 pints in new money I think
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
Re: Steering Idler
« Reply #9 on: 20 July 2017, 08:08:23 »
Febi fitted 3 years ago,absolutely no problem at all :y
mandula
  • Finland
    • Opel Omega -03, Z22XE man
Re: Steering Idler
« Reply #10 on: 20 July 2017, 08:55:18 »
Has anyone noticed that even with brand new bushing, before tightening it in place, there is some noticeable slack?
I have tried few years ago and couple of months ago again with two brand new bushings (Febi) and same thing both times. There is about 1-2 mm free movement between the shaft and bushing. Should it be like this or is my shaft worn down so much?
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: Steering Idler
« Reply #11 on: 20 July 2017, 09:08:15 »
  that's a lot of movement
Re: Steering Idler
« Reply #12 on: 20 July 2017, 09:09:51 »
Not something you get on the genuine ones or the (real) Lemforders
tidla
  • solihull
Re: Steering Idler
« Reply #13 on: 20 July 2017, 09:31:34 »
Vauxhall do that. Had the same kind of service. Try ringing another dealer if you want genuine.
Re: Steering Idler
« Reply #14 on: 20 July 2017, 19:33:10 »
That's because its shagged. Its not the shaft, its the shocking quality of the pattern ones.
Page created in 0.033 seconds with 20 queries.
