Author Topic: Brake pipe ?  (Read 6738 times)
EMD
  • Noofhampton
    • 95t
Brake pipe ?
« on: 24 July 2017, 14:06:50 »
Flaring too keeps pushing the steel brake pipe through the flaring too  ??? It will flare copper to double flare but just will not hold steel . Any solutions to this , ive got it clamped as tight as it will go but just keeps slipping  :(
Omegatitis
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Brake pipe ?
« Reply #1 on: 24 July 2017, 14:23:45 »
Is the tool correct for steel pipe?
kunifer is softer than steel and probably better too
e46 325i se - 1.8vvti avensis liftback
EMD
  • Noofhampton
    • 95t
Re: Brake pipe ?
« Reply #2 on: 24 July 2017, 14:35:10 »
I think ill be needing the on car flaring tool , this flaring tool is a cheapo and i suppose is not up to the job . Just thought there mite be a tip to stop the pipe from slipping .
Omegatitis
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Brake pipe ?
« Reply #3 on: 24 July 2017, 14:45:57 »
I was about to suggest, politely, that your tool might not be top quality - but you said it for me!  :y
Ron.
EMD
  • Noofhampton
    • 95t
Re: Brake pipe ?
« Reply #4 on: 24 July 2017, 14:53:38 »
Ron.
Yes , i just checked back on the flaring tool compatibility and seems this one is for copper only  :-[ I will need the on car flaring tool , will check whats available  :y
Omegatitis
Re: Brake pipe ?
« Reply #5 on: 24 July 2017, 15:15:57 »
This fella appears to be making a steel brakeline with the same tool I bought for doing copper: https://www.youtube.com/watch?v=S5cI42jE9wM
I could never get the damn thing to work on copper, mind, so this advice is worth precisely what you paid for it ;D
(Also fast forward to about 5:50 in to see the rookie mistake every one of us makes at least once per job.. ;D)
frostbite
    • 00' e46 325i se
Re: Brake pipe ?
« Reply #6 on: 24 July 2017, 16:04:45 »
Without watching let me guess, forgets the union?
Re: Brake pipe ?
« Reply #7 on: 24 July 2017, 16:07:34 »
 ;D ;D Yep..
Obviously not something I've ever done, you understand.
Bigron
  • Witham, Essex
Re: Brake pipe ?
« Reply #8 on: 24 July 2017, 18:22:59 »
Just like some people (NO, never me...) forget to put the cover on the lead first when wiring one of those rubber 13 amp plugs?
NEVER me, I said..... :-[
Ron.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Brake pipe ?
« Reply #9 on: 24 July 2017, 19:50:18 »
Ron.
I used to cut a notch out of the plug top when i did that Ron lad. ;) Just cut enough out to force the top on. ::)
tidla
  • solihull
Re: Brake pipe ?
« Reply #10 on: 24 July 2017, 20:02:32 »
Proper tool or do the complete section in a material your flare tool can handle.
Bigron
  • Witham, Essex
Re: Brake pipe ?
« Reply #11 on: 24 July 2017, 20:52:49 »
Ron.
Well, of course if I ever did that, it's what I would have done - but I never, NEVER....  :-X
Ron.
