Cycle racing throwing rubbish...
Started by Terbs, 30 July 2017, 16:29:37
On the proper road closed runs, I'm sure they do a sweep up after last ones have gone through.
Bigron
It's still a bad example for the young and impressionable; they are, apparently, role models for those ol single-figure I.Q.s.
Just like what little I see of those overpaid oafs on the football field, spitting in front of them as they go: now every high street has its young imitators doing the same disgusting thing.
Ok, I don't expect the morons from the shallow end of the gene pool that play football to behave responsibly, but from the posts on here I gather that cyclists CAN be better behaved. Sometimes. :-\
Ron.
Gaffers
All the races I have done have a zero tolerance for litter, no ifs, no buts, dont care if you are an amateur or a pro.  There are litter zones around the feed stations where you can drop your litter without punishment.  I remember one Ironman where the guy in the lead, by some considerable margin, accidentally dropped a gel wrapper outside on the litter zone.  The referee didn't hesitate, DQ.  Bye bye.
As someone who does a lot of spearfishing and freediving I see firsthand the effect litter has on the marine environment.  It's horrendous and I often come away from a fishing trip with a load of rubbish whether or not I catch anything.  Commercial fishermen aren't squeeky clean either.  I once nearly swam in to the remnants of a net which was suspended mid-water at about 8 meters.  It was only 2m sq but enough to have trapped me underwater had I not seen it in time.
Bigron
Pity the same stern rules don't apply to non-cyclists - those people who defile our streets and beauty spots. I fear smokers are the worst offenders, expecially now that they have, rightly, been banned from smoking in pubs and restaurants. look at the filth that they leave outside those places.
Sorry to hear about your near-entanglment: no excuse there, either.  >:(
Ron.
I am not going to go into the whole smokers debate... that there is only one smoking area airside, there used to be four, for the whole of Gatwick tells you everything you need to know...
But whilst a personal danger at that time, I cannot see how the fishermen would be responsible for a section of net... it could easily have snagged on a rock on the sea bed and been torn off... with relatively neutral buoyancy it will drift around undetected for years... the first the fisherman will know is when they lift the net and find a hole in it... no chance whatsoever of identifying where it happened and retrieving it :-\
Rods2
By far the worst offenders in the Camberley / Sandhurst area are car drivers that buy their fast food, congregate in local car parks, making lots of noise and making a nuisance of themselves well into the early hours of the morning, including revving engines and doing lots of donuts to wear their tyres out and all their fast food litter and other discarded items are strewn across the car park, which of course us council tax payers then have to pay for it to be cleared up! >:( >:( >:(
Personally, I think where the litter is branded each discarded item should incur a £100 fine for the fast food outlet. :y :y :y
scimmy_man
it wouldnt be hard to put a reg number on the packaging in the drive through
Gaffers
Quote from: Rods2 on 01 August 2017, 16:40:19
Yes the 2 Maccy D's in Farnborough are prime examples in point.  I often pop in for a sneaky breakfast on the way to the coast and usually swing by at about 5am before the cleaners have had a chance to clear the debris and it is quite frankly some of the most disgusting sights I have ever seen.
Gaffers
Quote from: Doctor Gollum on 01 August 2017, 16:36:49
Using nets in an area known for snagging is asking for loss/damage to nets.  They dont care about the debris they leave behind, just the fact they will have to repair/replace their net.  This particular occasion was less than 100m from the shore in 10-12m of water and everyone knows that the bottom can snag a lot.  There are outflow pipes and well charted rocks all over the area.  I dont mind so much when they lose a lobster pot, especially if it is at a depth I can hook a line on to it  ::)
