Pages: 1 [2] 3  All   Go Down
Author Topic: boot gas struts  (Read 11799 times)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: boot gas struts
« Reply #15 on: 02 August 2017, 17:07:29 »
Not to hijack but Is there a way to get the lid to swing open like a merc?
Or is that down to them having springs?
Is there enough space to get a slightly fatter strut for more power?
e46 325i se - 1.8vvti avensis liftback
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: boot gas struts
« Reply #16 on: 02 August 2017, 19:09:10 »
I would guess the easiest way for the lid to "Open like a Merc" is to buy a Merc   :D :D :D (sorry, couldn't resist  ;D)
frostbite
    • 00' e46 325i se
Re: boot gas struts
« Reply #17 on: 02 August 2017, 21:54:39 »
It would be a handy feature, to give an assisted lift if your hands are full
omega2018
    • MercCL500 Omega2.6ManElit
Re: boot gas struts
« Reply #18 on: 03 August 2017, 00:21:50 »
i suppose you could fit higher newton rated struts, strong enough to push the boot up immediately.  or play around with the angles.  might be difficult to close again ;)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: boot gas struts
« Reply #19 on: 03 August 2017, 10:18:56 »
My saloon boot lid just pops open a couple of inches when triggered. Is it supposed to open wide? If so I will replace with these. :y
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: boot gas struts
« Reply #20 on: 03 August 2017, 10:43:16 »
So does mine; then I have to lift it up using my incredible muscular power..... 8)
Ron.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: boot gas struts
« Reply #21 on: 03 August 2017, 11:14:05 »
yes mine just pops open :y
omega2018
Re: boot gas struts
« Reply #22 on: 03 August 2017, 12:52:07 »
no thats normal.  all the marelli struts will do is restore the factory performance - pops up a few inches then easy to lift the rest.  you'd need stronger struts to do more.  apparently some aftermarket struts do less i.e. more manual effort needed beyond the first 2 inches.
frostbite
    • 00' e46 325i se
Re: boot gas struts
« Reply #23 on: 03 August 2017, 13:50:50 »
You lot know what I mean, heres a video if you've never seen it.
Obviously it wont have remote open
https://youtu.be/AGeTd94--LM
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Re: boot gas struts
« Reply #24 on: 03 August 2017, 14:05:10 »
https://youtu.be/lPVhxNbq-kI
Or try this mod.....and tell us if it works
frostbite
    • 00' e46 325i se
Re: boot gas struts
« Reply #25 on: 03 August 2017, 14:11:38 »
That looks like it puts stress on the hinges more than the struts do when closed
Could be an idea to try though
Re: boot gas struts
« Reply #26 on: 03 August 2017, 17:29:52 »
Got mine from here. http://www.sgs-engineering.com/car-boot-tailgate/vauxhall/omega
£13 each, not bad. How have you found them? The 3.2's are getting quite weak
Can't remember where mine came from for TBE, but was around £22 delivered for the pair.  They're fine, and a million times better than the originals that came off.
Tempted to replace, but as I've lived with them like this for about 5 years not much point in replacing them now.
Laziness or tightness?
You could have had my old ones, as they still held up the bonnet ;D
Remember, it only takes a gust of wind.  For the sake of £22 and 10mins work, is it worth having a widow and fatherless child?  You know I ain't much on the H&S front, but given it would be a severe injury at best, and is cheap/quick to do...
Re: boot gas struts
« Reply #27 on: 03 August 2017, 17:33:43 »
But you need a free hand to press the button (on car, or remote), so can't see the gain.
Many posh cars with keyless entry do have a system where you can wave you foot under the bumper, which I guess makes this approaching useful.
The Shaguar has powered boot opening and closing. Apart from not leaving sticky fingerprints on the outside of the bootlid (not internal handles, as its powered), I'm struggling to see the point.
Re: boot gas struts
« Reply #28 on: 03 August 2017, 17:35:26 »
Nope, yours is bang on Shack, assuming with virtually no effort it raises when you lift it, then naturally moves to the completely vertical position.
Shackeng
  • Ramsbury
Re: boot gas struts
« Reply #29 on: 03 August 2017, 18:29:08 »
Yes, does that OK, but unlike you, I really love the auto boot opening feature on the new Mondeo Estate, and find it very useful. :y
Pages: 1 [2] 3  All   Go Up
Page created in 0.023 seconds with 20 queries.
