Pages: 1 2 3 [4] 5 6 7 8   Go Down
Author Topic: Charging Leisure Batteries on the move II  (Read 32631 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Charging Leisure Batteries on the move II
« Reply #45 on: 06 August 2017, 11:39:11 »
A quick google and I found this article.....tho they aint cheap...
http://www.12voltplanet.co.uk/battery-to-battery-chargers.html
Err yes, have you seen the price of them, seems like overkill :o
I like red cars
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #46 on: 06 August 2017, 11:52:28 »
Ouch, those prices! Gold plated?  :o
Ron.
« Reply #47 on: 06 August 2017, 12:13:35 »
' VSRs are not suitable for use with 'smart' alternators.' .....  ;)
« Reply #48 on: 06 August 2017, 12:45:38 »
 I could go on............
... and toilet for those night time visits  :y
I'm not old enough yet ;)
TD
  • Swindon
    • Nowt!
« Reply #49 on: 06 August 2017, 13:21:01 »
Yes....hence my comment
However those ones are quite heavy duty....I guess you could get away with a 10amp one...not sure what power rating your fridge is but I doubt the combined power consumption of the fridge and a fully charged battery is going to be more than 10A.
10A ones are cheaper  ;)
« Reply #50 on: 06 August 2017, 13:26:35 »
:( I am
TD
  • Swindon
    • Nowt!
« Reply #51 on: 06 August 2017, 14:26:44 »
Your not trying to tell us you don't need a night time bathroom visit after 10 tinnies of wife basher  ::) ;D
« Reply #52 on: 06 August 2017, 16:29:20 »
If you've got to get up anyway, you might as well walk a decent distance away rather than do it in your wardrobe, as far as I'm concerned. :o
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #53 on: 06 August 2017, 17:03:44 »
Strange habits you've got KW, you keep a toilet in your wardrobe :o
I like red cars
« Reply #54 on: 07 August 2017, 08:02:34 »
Is there not a 12V to 12V DC to DC converter available for battery charging purposes (may be as per used on solar panels)?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #55 on: 07 August 2017, 08:51:27 »
The caravan fridge when on 12v is controlled by a relay that only activates when the alternator is charging the main car battery, not worried about that as it can look after itself.
The caravan battery is on a direct feed from the car battery, and as such can give a reverse drain back to the car battery if the alternator ecu is not charging.
This feed also provides power to the Al-Ko ATC system, but is isolated from the caravan battery.
I need to isolate that feed to stop this happening, the caravan does not draw any power from its own battery whilst towing and will remain fully charged if not connected to the car allowing me to use the mover.
« Last Edit: 07 August 2017, 09:09:10 by Auto Addict »
I like red cars
« Reply #56 on: 07 August 2017, 09:08:43 »
Why not use a conventional voltage sensing relay? That will connect the caravan battery when the vehicle electrical system is at a high voltage and disconnect it when the voltage drops. You'll get some charging of the caravan battery when the vehicle battery is being charged and it will protect the caravan battery from being discharged.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #57 on: 07 August 2017, 09:10:36 »
That seems to be the best option, if I could find one.
I like red cars
« Reply #58 on: 07 August 2017, 09:12:40 »
I think I may have one in the junk box. Came with some towbar electrics but surplus to requirements. :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #59 on: 07 August 2017, 09:15:21 »
http://www.12voltplanet.co.uk/voltage-sensitive-relay-12v-140a.html
Would this do the trick?
I like red cars
Pages: 1 2 3 [4] 5 6 7 8   Go Up
Page created in 0.024 seconds with 16 queries.
