Author Topic: Car Alarm keeps going off  (Read 4702 times)
Gerry1234
  • Crewkerne
    • Vauxhall Omega
« on: 05 August 2017, 15:32:22 »
I am new on here, I have a 2001 Omega V6 estate and the alarm keeps going off, I am no mechanic, how can I stop it? Could it be the battery?
  • Auckland
    • Mazda MPV
Re: Car Alarm keeps going off
« Reply #1 on: 05 August 2017, 15:52:18 »
It might be the battery - there is a guide for checking the battery and charging system.
It might be the switch under the bonnet - sometimes the bracket gets bent and triggers random alarms.
It might be leaking batteries in the powersounder. If it is the powersounder at fault there is a 50/50 chance that the thing will burst into flames and destroy your car
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 05 August 2017, 16:12:25 »
It has happened more than once! :y
« Reply #3 on: 05 August 2017, 18:11:10 »
As an easy starting point, disconnect the bonnet switch & see what happens.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #4 on: 05 August 2017, 23:49:52 »
Last time my alarm kept going off intermittently on my Omega, it was the power sounder. Fitted a new one and all was well. Another indication of a faulty powersounder is three beeps when you lock the car.
Gerry1234
  • Crewkerne
    • Vauxhall Omega
« Reply #5 on: 06 August 2017, 13:00:05 »
Thanks for your reply, my car beeps three times when you lock the car, so it looks like the powersounder.
« Reply #6 on: 06 August 2017, 13:24:16 »
Unplug & remove then. Under driver's side of the scuttle.
Shackeng
  • Ramsbury
neil74
  • newport
    • 2.6 elite estate.
« Reply #8 on: 06 August 2017, 15:49:26 »
I was lucky with my one in so much as the batteries had leaked all over the board and destroyed any chances that a dead short could occur and ignite the car.
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #9 on: 07 August 2017, 18:41:08 »
I beleive there can also be an issue on estates with the rear window sensors ?
