Removing paving slabs .....
Started by Lincs Robert, 07 August 2017, 10:18:22
Lincs Robert
Ok, so SWMBO wants changes in the garden - all agreed.
An area which currently has plants will be paved, with another paved area being grassed. There are enough slabs on the current paved area to be moved to the new area. The issue is therefore how to take the current ones up to move them without breaking them, or as few as possible. I might sacrifice one to see how it's laid - - hopefully on a dry mix, but they all have a decent edging of cement around them.
I'm not over keen of extensive use of an angle grinder, so, any other ideas guys?
There is nothing special about the slabs, they are the simulated York stone ones with a mix of 3 shapes, large square, rectangle and small square. Just seems a shame to buy new when I could reuse them if they can be taken up without breakages.
Cheers - Rob
Unless laid on sand/soil you'll struggle :-\
Dry mix absorbs moisture and sets.
frostbite
Cold chisel and a club hammer then lever them up
e46 325i se - 1.8vvti avensis liftback
Once one is up the rest will lever up ok, cold chisel to remove the mortar and jointing.
Lincs Robert
Migv6 le Frog Fan
Your swmbo sounds like mine. "I want those slabs over there taken up and replaced with grass. And I want that grass over there taken up and replaced with slabs". :D ;D
As soon as you've finished, she will want to move house.  ;D
Quote from: Migv6 on 07 August 2017, 12:11:16
'ain't that the truth! I like living where I do, which is why all my projects remain unfinished. ;D
Shackeng
If laid to dry mix, it may be possible to re-lay them into sand or further dry mix without cleaning off the old mix. Heavy work, but allows re-use of slabs, which are not cheap nowadays. :y
