Author Topic: Fiesta water pump/cambelt  (Read 3774 times)
al brown
  • alton, hants
    • Rusty 97 3l estate
« on: 09 August 2017, 10:19:32 »
Morning all,
I am about to change the cam belt on the fiesta, its a 2011 and my question is, do I need to change the water pump at the same time. I understand the amount of work argument, but what's the current thinking? Removing a working component just because I'm close to it doesn't exactly make sense, especially if it gets replaced with a non genuine part (I haven't priced the parts either way yet).
Cheers, Al
If it aint broken, you aint trying hard enough
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Fiesta water pump/cambelt
« Reply #1 on: 09 August 2017, 10:42:02 »
If the pump is driven by the cambelt, then not replacing it is so stupid you might as well not change the belt.
Ford waterpumps aren't paragons of long-term durability, so I would probably replace it anyway. I see no point in insisting on genuine parts either.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 09 August 2017, 11:09:15 »
Morning all,
Cheers, Al
Petrol or diesel,engine size ?
other rides
al brown
  • alton, hants
« Reply #3 on: 09 August 2017, 11:18:52 »
1.25 petrol
I changed the pump on the omega when I did the belt, just want sure about modern cars, when I rang ford for their price (for a laugh) they had no intention of changing the pump unless I asked them to.
henryd
  • west cornwall
« Reply #4 on: 09 August 2017, 13:04:54 »
1.25 petrol
!.25 waterpump not cambelt driven so not important,what is important if doing it yourself is that crank and cam sprockets are not keyed so correct lock kit is essential :y
http://mccormicktools.co.uk/sealey-petrol-engine-setting-locking-set-125-14-16-18-20-23-16v-duratec-ford-mazda-volvo-belt-chain-drive-vse5515.html?gclid=Cj0KCQjw5arMBRDzARIsAAqmJexLJQAxG6PXyn7xesaty3PeLTyAF2uPQ67V1q-lDD1sBonIzAuMWycaAgJhEALw_wcB
« Last Edit: 09 August 2017, 13:09:05 by henryd »
other rides
« Reply #5 on: 09 August 2017, 16:41:39 »
1.25 petrol
I think I have a locking kit for these engines somewhere, if you need to borrow it, Al. :y
al brown
  • alton, hants
« Reply #6 on: 09 August 2017, 19:51:09 »
1.25 petrol
Yes I'd seen that they aren't fixed, other than that not read up to much on it other than all ford for a price. If the pump isn't driven by the belt then I will maybe just check it and replace if I've any doubt. I did read to replace it you need to remove the belt so I assumed it was belt driven.
al brown
  • alton, hants
« Reply #7 on: 09 August 2017, 19:52:24 »
1.25 petrol
Cheers Kevin, I think I've got one as it looks the same as for other size engines in the range.
If not I'll give you a shout.
Al
« Reply #8 on: 10 August 2017, 09:16:58 »
Yep, it's a flat bar to lock the cams and a pin to screw into the side of the block to lock the crank. IIRC, the pin is different from the larger Zetec E but the bar is the same.  :y
