Author Topic: vectra 2000 cambelt change.  (Read 3146 times)
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
« on: 14 August 2017, 17:28:35 »
Ive just rang up for a cambelt change on a vectra 2000 x18xe1 engine, They said it would be £400 even when i will supply the kit, does that sound about right ? I would do it myself but did not fancy doing it as the wheel has to come off and the engine mounts just to get to the belt etc. but is this about right for the price did not think it would cost that much. The vectra's probably only worth that price anyway.
Re: vectra 2000 cambelt change.
« Reply #1 on: 14 August 2017, 18:40:21 »
1.8 Vectra C belt was £120 in labour and included swapping the water pump and thermostat... parts customer provided... total was circa £250 iirc
Engine is broadly similar, so cost should be comparable  :y
Chazza12
  • south yorkshire
« Reply #2 on: 14 August 2017, 18:51:09 »
sounds like they trying to rip off, or make it so expensive so they don't doit. ??
« Reply #3 on: 14 August 2017, 19:03:03 »
My car shares an engine with a Vectra but uses a chain and not a belt.
85000 miles with no problems. :)
Chazza12
  • south yorkshire
« Reply #4 on: 14 August 2017, 19:15:06 »
its belt on this, its near to its end of life, timing out a bit according to timing marks, and asked when it was last changed and he cannot remember and he had it for 10 years. so it definitely needs a new belt and water pump fitting, water in engine is rust red. i will have to have a go at it sometime its not going anywhere till its done, its just trying to find the time to do it. have kit bought it from vx.
« Reply #5 on: 14 August 2017, 19:15:53 »
It happens... Some places are fussy about parts... Which is understandable as they need to be able to provide some sort of guarantee, both of their work and the parts.
That said, if you turned up with all the parts just collected from Vx with the receipt then you shouldn't have an issue :-\
Pay to shop around...
Chazza12
  • south yorkshire
« Reply #6 on: 14 August 2017, 20:17:19 »
i bought the parts as they (all ) use uni parts and did not like the idea of them parts being fitted. suppose they ok for fords as a cheap fix, not with the timing belt. ive used them on fistas and most managed was 3 years and then the belt needed replacing. so no to uni parts.
« Reply #7 on: 14 August 2017, 20:21:04 »
Vx service parts are cheap enough :y
Just need to find someone to fit them...
Might be worth asking local Vx dealer for a fitting quote... They occasionally have fixed price offers on certain jobs such as coolant/brake fluid and cambelt changes :y
Chazza12
  • south yorkshire
« Reply #8 on: 14 August 2017, 20:27:13 »
i will give them a ring in the morning, there is a vauxhall recommended garage about 8 miles away might try them as well.   :y
« Reply #9 on: 14 August 2017, 20:34:20 »
Even if they quote £250-300, you're still well ahead of the first quote :y
Chazza12
  • south yorkshire
« Reply #10 on: 14 August 2017, 20:46:31 »
most definitely, i was going to ask how much to do the mig clutch but think i will give them a miss. lol  :y
tidla
  • solihull
« Reply #11 on: 15 August 2017, 18:52:11 »
Fitting bits supplied is a pain in the head, more so when its something as critical as a timing belt. End of.
Incorrect, cheap, updates and Warranty issues.
Did i mention it being a pain ?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 15 August 2017, 19:16:33 »
This.
The OP might be surprised if he gets a quote from the same garage to supply and fit the parts.
Chazza12
  • south yorkshire
« Reply #13 on: 16 August 2017, 00:38:01 »
had a word at the vauxhall recommended garage, said he could do the job next week as he fully booked up this week so its going in and staying the night there. £175 with vat.  so going to drop it off and come back on the bus. next tuesday,  :y :)
Page created in 0.136 seconds with 20 queries.
