Author Topic: full steering lock noise  (Read 1878 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 15 August 2017, 20:52:29 »
it seems my mig doesn't like a full steering lock . it squeals . any ideas what causes it
  • Auckland
    • Mazda MPV
Re: full steering lock noise
« Reply #1 on: 15 August 2017, 21:17:30 »
Holding the steering against the stop puts immense strain on the power steering.
There is a pressure relief valve in the hydraulic pump to prevent the hydraulics springing a leak (which will make a hissing noise) but the noise you are hearing is probably the auxiliary belt slipping.
If it isn't the belt then suspect the pump.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #2 on: 15 August 2017, 23:12:20 »
Most cars give a groaning / squealing noise from the power steering if held on full lock - more noticeable when stationary or at very low manoeuvring speeds. Belts also squeal when they are damp or glazed through age.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #3 on: 15 August 2017, 23:29:58 »
My 4banger is currently stalling if held on full lock on tick over, icav and breather jet are due a clean  >:(
e46 325i se - 1.8vvti avensis liftback
