Author Topic: 3.2 Transmission swap  (Read 4095 times)
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« on: 16 August 2017, 16:16:49 »
Afternoon,
I sourced a spare ar35 from omegas52 on ebay, its coming to me on friday.
The thing is, no one round here is prepared to swap the boxes for me. (We dont touch automatics mate) etc etc.
I dont have access to a ramp, but im considering trying it, can anyone give me their view on this please?
How long might it take for example?
The old box has needed topping up every two weeks for a while, now its undrivable.
I would really rather not do it but its looking like i dont have much choice.
Help!
Re: 3.2 Transmission swap
« Reply #1 on: 16 August 2017, 16:31:11 »
I'd say if you can get the car up on ramps it's do-able in a day with a helper.
Make sure you install the torque converter fully home on the transmission before offering up the whole assembly and then bolt the torque converter to the driveplate with the whole lot in-situ. Don't be tempted to attach the TC to the driveplate first and then offer up the transmission as this will destroy the seal.
« Reply #2 on: 16 August 2017, 16:36:10 »
If your prepared to travel, Autoeurope in Charlwood is recommended  :y
Transmission swap is circa £2-300.
steve6367
« Reply #3 on: 16 August 2017, 16:38:38 »
Afternoon,
The thing is, no one around here is prepared to swap the boxes for me. (We don't touch automatics mate) etc etc.
I don't have access to a ramp, but I'm considering trying it, can anyone give me their view on this, please?
The old box has needed topping up every two weeks for a while, now it's undrivable.
I would really rather not do it but it's looking like I don't have much choice.
Help!
I've done it on the drive before with 2 ramps and a couple of jacks (for the box) - now I think I could do it in 1 day, the old off and the new one on. The first time it took me 2 days.
I would allow 2 days, you might be pleasantly surprised and do it in 1  :y
« Reply #4 on: 16 August 2017, 17:33:54 »
DLK planned to do mine on axle stands in a day ... luckily it wasn't required in the end ....   :)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #5 on: 16 August 2017, 18:44:47 »
Afternoon,
Help!
Ive also changed one on my drive in a day using the same method, without an assistant. It was hard work but its doable.
Care is needed though as its heavy and hurts like fack if it falls on your hand.  ::)
Cant understand a garage turning the job down for any reason. Its basically a load of nuts & bolts to remove, and then put back. Nothing technical about it.  :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 16 August 2017, 19:36:06 »
I'm 80 and did mine a year or so ago in the garage on my own using axle stands. I didn't find it easy because I am not quite so agile as I once was, but it is certainly doable on your own. I borrowed a gearbox jack from Joff, but when JamesV6 swapped boxes for me a few years ago, he used two jacks. I found the most awkward jobs were lining up the box to mate it to the engine, and tightening the top bell housing bolts which required about 3' of extensions. :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #7 on: 16 August 2017, 21:43:48 »
Afternoon,
Help!
I never turn job away :)
Omega gearbox replacement is pleasure to do on ramp compare to some other cars
Like merc b class where you need to remove engine and gearbox to replace clutch
Duke01
  • Southampton
    • 03 3.2 Elite Lpg
« Reply #8 on: 16 August 2017, 23:05:44 »
Thanks everyone, will have a go this weekend.
Unless anyone wants to earn some money...
Am in Southampton  :y
« Reply #9 on: 16 August 2017, 23:08:50 »
It's probably an indication that they don't know their @rse from their elbow, TBH. ::)
Migv6 le Frog Fan
« Reply #10 on: 16 August 2017, 23:17:38 »
Absolutely, but it makes me wonder how they make a living from it. Ripping off the gullible is probably the answer.  :(
« Reply #11 on: 16 August 2017, 23:20:53 »
Yep, no profit in doing jobs for people who know what's wrong and roughly how much they should be charged. ;D
Migv6 le Frog Fan
« Reply #12 on: 16 August 2017, 23:27:06 »
Ive just realised, after many years of wondering,  why I have never made any money.  ;D
Stupidity may also have something to do with it though.  :-[ ;D
« Reply #13 on: 17 August 2017, 20:46:36 »
I remember I turned up a Sassanach's place circa 4pm one Sunday, he had the (utterly shagged) AR25 off the car, stripped to component pieces to prove the clutch plates were non existent, the AR35 bellhousing off (as was going on a TD), thrust washer replaced with Sonex, bolted back in place, filled up with ATF, and I was gone by 7pm, after a quick brew.
But then he did know his autoboxes, plus being a TD, the cats didn't have to come off.
