Author Topic: When towing Caravan +normal load in car the riding height (rear) is quite low  (Read 8276 times)
Thanks Entwood, Nice to get you to this discussion, too. Remember you said once "Omegas are excellent towcars, without any doubt whatsoever" which I really agree now after this Summer. What is your solution or does Elite have automatic height control?
yup .. and excellent it is  .. :)
I agree.  But Airmatic is even better  :y
What's this, something I shoud know, too??
Sorry. It was a joke. Airmatic is what Mercedes call their air suspension.  :y
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
OK, no problem, I am still not sure which way to go. Monroe solution would be easiest way but are the that poor dampers?
Heard that Volvo have also a solution which pumps it by itself to right height.
It's what his posh Merc has .....  :)
Does the same thing but costs 15 times as much and breaks  more often ..........   :)
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Didn't Cliffo B have airbags fitted inside his springs :-\
If I recall, he had an Elite estate, but found that the 80l LPG tank, a mobility scooter and a caravan were all a bit too much for the self leveling system...
That surprises me, because I tow a car transporter with a 3.2 Elite saloon, and even loaded with a medium sized vehicle such a Golf or Audi A4, the ride height isn't much lower than when solo. It just has genuine GM self levelling springs and shockers fitted. Obviously, the self levelling system needs to working properly and not loosing pressure under load. With the caravan on the back, it doesn't look any different to normal when the self levelling has done its job.
  • Online Online
I believe the issue was with the rear axle loading rather than the caravan... boot load was probably around the 250kg mark without the caravan nose weight :-\
If the springs were past their best, then the factory air shocks can only do so much.
Does the same thing
It doesn't  :D You can't raise your car & you don't  have comfort/normal/sport settings  :y
I'll let you have the cost bit, but contest that breaks more often   ;) though I've had two new rear shockers recently at €400  :(
polilara
  • Finland
Has anybody else experience of these?
https://www.amazon.co.uk/Monroe-LA360-Shock-Absorber-pieces/dp/B00DQC72PA
Is that the way e.g. what is installed in Elite?
  • Online Online
They attach in the same way as the standard shock absorber :y
Only differences are saloon or estate and you plug the cars existing air supply to them.
Retrofitting the system is easy enough.  :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
I fitted MAD progressive to my Omega, easy to fit and worked a treat :y
I like red cars
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Do you think the kinetic nivomats from a volvo do a good job?
They sort of self level when there is movement
e46 325i se - 1.8vvti avensis liftback
polilara
  • Finland
I think it is really good solution, just shocks and no other components, friend of mine have it in Volvo V70. He is very satisfied with them. Unfortunately not available for Omega.
http://www.roversd1.info/nivomat.htm
polilara
  • Finland
I perhaps can get new original Omega pneumatic shocks to rear. If I am happy with manual height adjustment just by adding pressure when needed what other parts I need than shocks. Do I need a pressure tank etc. or can I just add air direct  to shocks.
