Author Topic: Cam cover gaskets  (Read 3469 times)
Cam cover gaskets
« on: 26 August 2017, 13:16:46 »
What's the current recommendation?
I know there have been a few successes with pattern ones, I'm just not sure which :y
Thanks!
Re: Cam cover gaskets
« Reply #1 on: 26 August 2017, 13:17:41 »
Also, the breather seals and o rings - where to buy? dealer says no!
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 26 August 2017, 16:00:23 »
Don't know about what gaskets are being used.Last year I bought a pack of seals from Vx stealers that are described as o rings,it consists of four round ones and one that looks slightly deformed as it looks like a not quite formed figure 8.The part number for the pack is 90500983.I believe the one that's hard to source[if it's possible at all]is the one that sits beneath the breather bridge.
BazaJT
« Reply #3 on: 28 August 2017, 18:26:27 »
Wasn't Webby running something like Payen gaskets?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 28 August 2017, 18:46:38 »
Elring on mine for the last 3 and a half years. They were part of a £12 head set, that I used all of. I didn't have new O rings, so gave them a smear of silicone.
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
« Reply #5 on: 29 August 2017, 07:42:29 »
I've used Victor Reinz on mine, installed 2.5 years ago, and all good for now. Previous set was the same manufacturer, almost no leaks for over 4 years.
Not sure how common this manufacturer is in UK. I'd go for erling if VR wasn't available.
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #6 on: 05 September 2017, 21:54:37 »
Used Victor Reinz on mine too,so far so good
Keith ABS
  • Maldon Essex
« Reply #7 on: 06 September 2017, 08:03:28 »
  Which "O" rings do you require? I have sets of the inlet manifold rings, £8 a set posted
Keith ABS
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #8 on: 17 September 2017, 14:00:28 »
I am in need of cam cover gaskets. I bought a set from Leader Specialist Components, Redhill Surrey, presuming they would be the same as supplied previously, and depicted in their e-bay advert. they sent instead Hans Pries TOPRAN gaskets, labelled ERSETZT - replacing. They seemed all right, fitted OK, but on first fitting one of the 1-3-5 gaskets became displaced and got cut in 2, I fitted a second one, it seemed OK, but now that side is smoking, suggesting an oil leak.
Where do I get Payen or Elring cam cover gaskets?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 17 September 2017, 15:41:00 »
I can probably get Elring I will check and let you know :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #10 on: 17 September 2017, 18:58:10 »
Reintz gaskets come with O rings
