Author Topic: Another years ticket BUT .............  (Read 16131 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Another years ticket BUT .............
« Reply #30 on: 10 September 2017, 09:00:08 »
Did you ring Pedders? As they would have answered your queries ::)
3.Yes the rear mounts are the diff ones... these will either be fine or already shot. If shot they can be recast in either poly or resin... I went resin and the back end was absolutely rock solid 8)
1. Do one side at a time. Remove the plate, lever the bulk out of the middle, might even fall out. The get a cold chisel and insert into one of the notches on the flange, obvious once there... then smash ten bells of shit out of it... aim is to make that point reach the centre of the space. Flange and remnants should pull out with minimal fuss.
You can piss about with a pair of claw hammers, but why bother?
2. Poly donuts are simply a push fit. A wipe of copperslip will prevent squeaking.
If not fitting polys, don't heat them... the standard ones contain a metal flange which will expand and you'll never get them in ;D
Eh no
Not had time  ::)
Getting up at 05:30 / Mon - Fri
Getting home after 18:30 so totally oppsed
Just trying to get as much info before I rip it all apart  ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #31 on: 10 September 2017, 09:01:31 »
I used rubber grease for the ones I fitted.
Red stuff ?
Stinks like shit ?
Got some somewhere  ;)
« Reply #32 on: 10 September 2017, 14:43:20 »
They aren't rubber ::)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #33 on: 10 September 2017, 17:58:05 »
Rubber grease isn't shit but it sure smells like it  :D :D
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #34 on: 11 September 2017, 08:24:15 »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #35 on: 11 September 2017, 19:15:56 »
There here  :D :D
A big thanks too our Dutch member Peter (Vega) for answering my call for help  :)
I'll let you all know how it goes around weekend if / when I get chance to have a play :y
Lincs Robert
« Reply #36 on: 11 September 2017, 22:44:56 »
Steve,
I'm pretty sure that they HAVE to be fitted a particular way, alignment marks maybe?
I had a pair incorrectly fitted once and it certainly livened up the ride a bit!
They had to be taken out & put back in the right way - whatever that was  :-\
Good luck
« Reply #37 on: 11 September 2017, 23:17:17 »
Steve,
Good luck
No such faffing with the poly ones...
Standard ones do indeed have a particular orientation... iirc, the structure of the bush should point towards the diff :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #38 on: 15 September 2017, 16:34:15 »
Right, got the plate off curtesy of my new impact gun and lots of plus gas.
Rubber bit in the middle took a screwdriver in the middle and a bit of a tug and twist.
Now for the sleeve  :'(
Are these fookers normally pressed in with some sort of mastic / panel sealant ?
Well this bugger is ..........  ::)
1 1/2 hours upto now and its out by about a inch  >:( >:(
« Reply #39 on: 15 September 2017, 16:52:09 »
Rear donuts? I rammed a brake caliper in the gap, then extended that, it pushed it out nicely  :y
« Reply #40 on: 15 September 2017, 17:09:11 »
Hammer and cold chisel and smash ten bells of shit out of it across the car...
Should just pop out then ;)
No point spending hours pissing about and straining yourself...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #41 on: 15 September 2017, 18:16:22 »
Well the 1 1/2 hours of abuse must have made it scared  :D so it only took another few slaps to fall out  :y
A good dose of Lidl's good stuff washing up liquid and a bottle jack got is started enough to get the freshly wire brushed and painted plate back most of the way on then the centre bolt bit and 5 minutes later its rebuilt the wheels going on  :y :y
I did leave the smaller top piece of bush off which sits ontop of the arm between the arm and the chassis because the original rubber one was in unmarked condition. Hoping that this will kill any NVH problems and still give me more control of the back end  :y :y
Looks like tomorrow will be same shit, another day when I do the other side  ;D
Just to add if your after a impact gun and don't mind spending a few quid, Have a look at the Ryobi one.
400 nm of twisty action for 100 quid with a 3 year warranty but beware you will need to by a battery and charger too if you aint got one  :-\
These bolts had been in there for 15 years and it pulled them out like a hot knife through butter (other spreads are available  :P)
« Reply #42 on: 15 September 2017, 18:54:50 »
Fit the top pad.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #43 on: 15 September 2017, 22:56:01 »
Fit the top pad.
Why ?
Any option on this  ::)
Can I phone a friend  ;D
I take it the rubber pad should be removed ?
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #44 on: 15 September 2017, 23:39:11 »
Last time I replaced the doughnuts, I used a 3 legged puller with the legs knocked into the notches in the bush which started them moving slightly. I put suitably placed blocks of wood between the body and subframe, and supports under the subframe, with a long narrow bolt to fit in the centre of the bush with a nut for the puller to push against using the block of wood to retain the head, and they both came out reasonably easily in one piece. It just needs a bit of thinking, as you have forces pushing in both directions when you wind them out.
Pages: 1 2 [3] 4  All   Go Up
