Author Topic: Self leveling.  (Read 7884 times)
Omega Nige
  • Oxfordshire
    • Omega 3.2 V6 Elite
Self leveling.
« on: 01 September 2017, 23:16:38 »
Hi, on my 3.2 Elite I am replacing the rear springs and shocks to the standard set up. As I will not need the level switch for the gas struts can I use this switch for the zenon lights as they are not working? Thanks :)
Re: Self leveling.
« Reply #1 on: 01 September 2017, 23:20:34 »
Level switch?
Re: Self leveling.
« Reply #2 on: 02 September 2017, 00:03:05 »
No.
The suspension level sensor is effectively an ecu, the headlight level sensor is completely different.
Re: Self leveling.
« Reply #3 on: 02 September 2017, 00:16:39 »
So ..... NOT standard then  ???
Re: Self leveling.
« Reply #4 on: 02 September 2017, 09:28:08 »
No, you cannot us that in place of either headlight level sensor.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
Re: Self leveling.
« Reply #5 on: 02 September 2017, 09:33:41 »
1. What is the difference between Elite springs and standard springs.
2. Are Elite Shocks air pressure ones
3. Can Elite Shocks be used with standard springs in "standard" Omega e.g. by installing hoses and add air from e.g. boot.
Still evaluating how to control rear height when towing...
Re: Self leveling.
« Reply #6 on: 02 September 2017, 09:38:31 »
1) Elite ones are softer
2) Yes
3) With some modifications, I see no reason my not, but would be a fair amount of faffage - I think I'd be fitting the ECU and pump to automate it.
polilara
  • Finland
Re: Self leveling.
« Reply #7 on: 02 September 2017, 10:02:55 »
2) Yes
Thanks, modifications? I mean are they mechanically the same so just put there and create any manual system for pressured air?
Re: Self leveling.
« Reply #8 on: 02 September 2017, 16:45:00 »
2) Yes
Easy enough to retrofit the factory system... level sensor on right hand rear trailing arm IS the ecu... plug and loom should be visible/present beneath the rear seat insulation... pump mounts to front chassis ahead of right hand wheel beneath headlight housing... if sensor wire is present, plug for pump should also be there... might be bundled into headlight wiring ;)
No wiring present makes it much harder to do.
polilara
  • Finland
Re: Self leveling.
« Reply #9 on: 02 September 2017, 16:59:13 »
Thanks Doctor Gollum, have to think that factory system, too. I check what wires etc are already there. I ordered by now only the rear shocks + some tubing. Let's see what I get, I did not understand exactly what tubes the seller said that I need. My idea was first just to put air there to make the position of car good when towing a mobile home and let air go when not needed. Are standard rear springs OK for this?
Re: Self leveling.
« Reply #10 on: 02 September 2017, 17:04:09 »
Standard rear springs will be fine as they are slightly firmer than the Elite spec ones... ride comfort over handling on the Elite ::)
The pump, sensor/ecu, pipes and relay you should be able to get from a breaker... new shocks is probably best though.
An easy days work to refit :y
polilara
  • Finland
Re: Self leveling.
« Reply #11 on: 02 September 2017, 17:16:43 »
OK, Elite might be Opel Omega Executive -model here. Never seen in Finland, have to check breakers in the neighborhood.
Re: Self leveling.
« Reply #12 on: 02 September 2017, 17:27:33 »
RobseyMV6 might have everything you need ;)
bootie
  • Enix, Almeria, Spain
Re: Self leveling.
« Reply #13 on: 02 September 2017, 19:08:15 »
If you wanted to go the manual air route might I suggest looking for any of the larger engine Omega A estates.
My 2.6 CDXi has the same air assist shocks but the air lines route to a simple Schrader valve located in the boot floor. I normally keep 5 psi in the system which makes the back end (unloaded) the same height as any other Omega A estate.
I keep a measuring stick with that height marked and when I tow, or load up the boot I use that when putting air in (using a bicycle pump) until the same height is reached, however I have been told previously that I should never exceed 30psi as the bellows may just rupture.
I never put more than 15 psi even when I collected 0.5t of fire wood.
Might be of use to you.
polilara
  • Finland
Re: Self leveling.
« Reply #14 on: 02 September 2017, 20:05:32 »
Thanks bootie, this is what I am looking for first. Perhaps later something Doctor Gollum informed. I ordered a "pipe" set for those shocks. Might be something similar to what you told. Let's see.
