Author Topic: Quick saloon bumper reattacment  (Read 2107 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 20 September 2017, 22:21:17 »
SWMBO did this tonight.Daughter needs this car on Sunday. Does it need any plastic bits?
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Quick saloon bumper reattacment
« Reply #1 on: 20 September 2017, 22:44:59 »
Local body shop fixed mine back on with some long screws/bolts and large dia. washers.
« Reply #2 on: 21 September 2017, 06:20:40 »
Probably torn the wheelach liner where it screws through, certainly torn the four fixing points under the boot lid.
Open boot, remove four retaining screws. Clean area across boot aperture and back of bumper. Run a bead of Sikaflex ebt across between the screw holes, and refit bumper using the original screws.
Can do same for wheel arch liner fixing points, but clean/degrease thoroughly.
Cannot tell from picture, but suspect that the two plastic rivets beneath the bumper are missing. Replace/reattach with stout cable ties.
Job jobbed :y
terry paget
    • 3 Astras 2 Vectra
« Reply #3 on: 21 September 2017, 20:30:02 »
Job jobbed.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 21 September 2017, 20:31:34 »
ronnyd
« Reply #5 on: 21 September 2017, 21:17:05 »
Looks better than mine Terry ;D
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
« Reply #6 on: 21 September 2017, 23:08:49 »
Job jobbed.
We share the same rust spot on the boot😀 a common problem for facelift Omega’s?
