Pages: 1 2 [3]  All   Go Down
Author Topic: Replacing ignition barrel  (Read 10201 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Replacing ignition barrel
« Reply #30 on: 24 September 2017, 22:10:34 »
It only takes five minutes to replace the levers! Mind, you have to take the old ones out to identify them first. ;D
« Reply #31 on: 24 September 2017, 22:11:50 »
It only takes five minutes to replace the levers! :y
A new barrel could be fitted before the kettle boils...
Shackeng
  • Ramsbury
« Reply #32 on: 24 September 2017, 22:15:58 »
If you have one to match your key, or with its own. :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #33 on: 28 September 2017, 18:10:08 »
Replaced this today. Took ten minutes and all is now good again. I also had a spare blade in the kit the same as my current key so all good. 54 quid inc. vat.
Only thing to note is I couldn't get the 3mm Allen key in for some reason. So used a 2mm and the barrel popped straight out. Moved steering lock down with flat head and popped new one in. Job jobbed  :y
Cheers for all the help  :y
Now to look at this suspension.....  ::)
RIP Paul Lovejoy
« Reply #34 on: 03 October 2017, 09:38:59 »
Ugh, that's a big snag: in order to phone the numbers through, I have to demolish my lock, and no car until I get the new tumblers!
Ron.
you could rebuild it in between ....  ::)
Yet more buggering about for a five minute job!
I wish I could justify that amount of time and effort.
Depends how much free time you have  ;)
I wouldn't even have considered it last year when I was unemployed.
Ah but its all down to what individuals prefer to do with their time.
Personally I take a lot of satisfaction in fixing things like this rather than bin and replace, given its a short and simple job (and a fix can be made in the interim with a file) its time better spent than say 30 minutes in front of the TV  :y
Pages: 1 2 [3]  All   Go Up
