Cookery experts?
Started by Shackeng, 23 September 2017, 11:13:30
Tony H
Don't bother pre soaking lasagne sheets even if they are the pre soak ones after 35 years in the catering trade and cooking thousands of portions of lasagne I find that the pasta absorbs enough moisture  from the sauce's to cook it to perfection :y
Lizzie Zoom
#16
Quote from: Tony H on 23 September 2017, 18:22:43
I understand that in the mass catering industry methods of cooking can be different, but in domestic and resturant catering standards are higher as costs can be absorbed and justified easier.
I have been cooking for at least 55 years, and all the receipes for Lasagna in the domestic arena specify cooking the main meat mix, then cheese sauce separately , bringing them together with the pasta sheets cooked or at least soaked (as I do) in salted boiling water for a time dependant on type, for example fresh pasta sheets for about 5 minutes.  Some receipes may specify that you leave the assembled mix to stand for about 6 hours, but us busy mums let the soaked fresh pasta sheets absorb the flavours in the extra cooking of an already hot mix for an additional 10 minutes, or until happy with texture and appearance, which in turn depends on your oven being fan assisted or not.
So what you do in the factory mass catering environment may well be different, as I am sure at least your ovens are operating in a different way than a domestic oven, and the methods used to assemble the lasagna mix in the first place reflect commercial requirements :y
hercules
2nd that  :y
Gaffers
Quote from: hercules on 24 September 2017, 21:46:53
2nd that  :y
3rd-ed.  I have been making lasagne for over 20 years and never once pre-soaked the pasta sheets.  One thing I would advise is to melt in some grated parmesan as well as cheddar in to the cheese sauce you add to each layer and the topping.  I also find that it is better if you make the bolognaise a day before and let it cool completely before using whether that's for lasagne or just straight spag bol.
Yep, I always just put the dry lasagne sheets in-between the sauces and then cook in the oven.
Clearly no write or wrong on this one as both methods work.
Lizzie Zoom
Quote from: Fuse 19 on 25 September 2017, 11:48:05
I cannot argue with that.  It is what works the best for each cook / chef :y :y
Varche
Quote from: Guffer on 24 September 2017, 21:56:23
2nd that  :y
4 th'd . That allows it to fester :y
Shackeng
Quote from: Lizzie Zoom on 23 September 2017, 19:35:12
Lizzie you still don't say how you stop them sticking together during your softening process. :-\
Lizzie Zoom
Quote from: Shackeng on 25 September 2017, 15:38:37
In post #11 i said:
"With fresh pasta sheets purchased from the main supermarkets they come with waterproof separates between each sheet (often 6 in a pack).
You place the cold sheets in a baking dish and pour on boiling water and leave for 3/5 minutes.  You then carefully drain the water off and lift each sheet in turn as you place in your lasagna dish, disposing of the separator sheets."
Hope this helps Shackeng :y :y
Amigo
If all else fails buy lamb mince/aubergines & make a Moussaka ;)
Shackeng
Quote from: Lizzie Zoom on 25 September 2017, 16:18:45
Thanks Lizzie, I should perhaps have mentioned that these are gluten free pasta sheets for SWMBO, and come without seperators. :y
Shackeng
Sorry for delayed replies, all very helpful, thanks. I will try to incorporate most if not all of these in my cooking. :y
Lizzie Zoom
Quote from: Shackeng on 29 September 2017, 19:16:50
Ah, that is different. I would then suggest you try and put grease proof paper or tin foil between each sheet ;)
Migv6 le Frog Fan
Men cooking ! ??  :o This is a new one on me.  ;D
