Author Topic: h 7 bulb  (Read 3867 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
h 7 bulb
« on: 23 September 2017, 20:00:46 »
does this h7 bulb just pull out of the headlight ?
Re: h 7 bulb
« Reply #1 on: 23 September 2017, 20:57:12 »
There's a clip that holds it in place.
raywilb
    • Citroen C4 Cactus
Re: h 7 bulb
« Reply #2 on: 24 September 2017, 12:18:27 »
does that clip lift up or do I have to squeeze it . tried both but its not moved.
Re: h 7 bulb
« Reply #3 on: 24 September 2017, 16:50:00 »
It's been a while since I did an Omega's .... but i think you squeeze them together so that each side clears a small hook on the back of the headlight. Most cars are a variation on that theme.
As you have a facelift, the headlights come out pretty easily ...... you'll be able to see what you're doing then. Or borrow a make-up mirror from SWMBO and have a look with that ;-)
« Last Edit: 24 September 2017, 16:52:15 by Andy B »
raywilb
    • Citroen C4 Cactus
Re: h 7 bulb
« Reply #4 on: 25 September 2017, 12:05:08 »
cheers :y :y
mandula
  • Finland
    • Opel Omega -03, Z22XE man
Re: h 7 bulb
« Reply #5 on: 27 September 2017, 13:13:51 »
Maybe you have already sorted it out, and I dont know are there any differences on year models..
But on mine -03 with xenons the hi-beam H7 just needs to be lifted upwards from base after connector is detached. New bulb then just needs to be pushed back in.
