Author Topic: Porous wheel  (Read 11230 times)
2boxerdogs
Re: Porous wheel
« Reply #15 on: 24 September 2017, 15:05:57 »
Seem to be going in circles on this topic.😀😁😂
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Porous wheel
« Reply #16 on: 24 September 2017, 16:29:02 »
I am STILL unclear as to whether the tyre or the wheel itself is the problem; could you please elucidate?
If it's the tyre and to a lesser extent the wheel, may I suggest a liquid rubber compound called OKO: I have had great success with this in the past. Viscous yellow fluid which sticks like shit to a blanket and seals/hardens at any leak site when exposed to air.
Ron.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Porous wheel
« Reply #17 on: 24 September 2017, 18:30:06 »
I put a tube in my wheel barrow tubeless tyre. Is that OK? :-\ :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Porous wheel
« Reply #18 on: 24 September 2017, 18:33:51 »
;D ;D
Re: Porous wheel
« Reply #19 on: 24 September 2017, 18:43:23 »
Do you race your wheel barrow?  :-\
2boxerdogs
Re: Porous wheel
« Reply #20 on: 24 September 2017, 18:57:51 »
Or take it on the motorway ?
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Porous wheel
« Reply #21 on: 24 September 2017, 19:00:38 »
If it's got wheels, you can race it!
As for my issue, it is the wheel that is porous, tyre is fine and the rim is fine and the bead seals.
Car is the blue one in the link below
www.chateauimpneyhillclimb.com/blog/mclaren
Used to belong to Patsy Burt and is the only one left of those that Bruce Mclaren built, hence the desire to keep it original.
If it aint broken, you aint trying hard enough
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Porous wheel
« Reply #22 on: 25 September 2017, 21:34:20 »
I'm assuming this is a magnesium wheel.
Car type, wheel type might help.
Hoof'land storeman.
al brown
  • alton, hants
Re: Porous wheel
« Reply #23 on: 26 September 2017, 08:27:32 »
Yes, I think it's a magnesium wheel. It's a Mclaren M3A, one of only 3 built and the only one surviving, one is unknown, one is in parts in Australia or New Zealand they think.
Other than that I don't know exactly what wheel is fitted, other than it is what came with the car when it was sold after Patty's death and is what it was displayed with when it was loaned to a museum after she retired.
Re: Porous wheel
« Reply #24 on: 26 September 2017, 10:35:36 »
There is a company in Slough called Ultraseal which can vac impregnate mag alloys with a resin to address the porosity issue.
A bigger concern is the structural state of them (and the others) as they are not know for their long term durability (but would be fine for display etc) so a structural test would be advised.
al brown
  • alton, hants
Re: Porous wheel
« Reply #25 on: 26 September 2017, 11:27:45 »
Cheers, I will look them up. The wheels racing days are clearly over and I guess the others are not far behind add they are all the same age. Putting 350 HP through a weakened wheel isn't the best plan.
I think they are all off for an X-ray, I know the leaky one has already been. I think the issue is getting a company to stop it leaking is hard as they will assume it will be driven in anger so won't want to take liability.
Maybe time to admit defeat and just replace it, however she is still refusing to use an electric fuel pump to get her alpha Romeo around and is still using the 1920's vacuum feed, with all the problems that generates with modern fuel.
Like she says though, cars are only original once and when you start changing them, where do you stop.
Re: Porous wheel
« Reply #26 on: 26 September 2017, 16:31:06 »
Which approach is best? Keep it clean and in a museum display or keep it road ready and able to be seen, appreciated and used in a manner more befitting a car of that pedigree?
Age old dilema that... and rare that the two paths are not mutually exclusive.
Re: Porous wheel
« Reply #27 on: 26 September 2017, 18:23:05 »
Sounds like your friend needs two sets of wheels, a good set for driving and the originals for display purposes.  :y
al brown
  • alton, hants
Re: Porous wheel
« Reply #28 on: 26 September 2017, 20:19:20 »
She has many more cars than just that one and they all get to go out and play. She isn't one for locking them away so no-one else can see them.
As she puts it they are only hers for now, someone else will own then when she's gone and it would be unfair to hide them from people who would like to see them. She let's her gardener borrow her e-type!
I will look into getting the wheel in with ultraseal, so at least it can be presented in its original condition and she can sort getting some replacements made for when she runs it in anger.
Thanks for the info
