Author Topic: Radio connector pinout  (Read 4088 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 29 September 2017, 18:34:46 »
Can anybody help me with the pinouts on this connector from a CART2007 Phillips unit. Number 17 - 36. As you can see on the image some are not used.
Image is flipped so that the numbers match the label on the radio, unfortunately number  17 - 36 isn't labeled. I am mainly looking for the connection to the steering wheel buttons.
On my other Omega that cable is in the lowest connectors #5 and that one is not used here.
My cable adapter has connections at the following positions:
18-23
27
32-36
So there is a mismatch in some
« Last Edit: 29 September 2017, 18:44:22 by Jan Suhr »
Jan Suhr
Stockholm, Sweden
www.protouring.se
Re: Radio connector pinout
« Reply #1 on: 29 September 2017, 18:44:18 »
What age is the car you are comparing it to?
Jan Suhr
  • Nyköping, Sweden
« Reply #2 on: 29 September 2017, 18:44:52 »
Its a 2002
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #3 on: 29 September 2017, 18:50:52 »
Should be the same, but equally be irrelevant if your replacing the unit with non factory  :y
« Reply #4 on: 29 September 2017, 18:56:55 »
Be aware than GM label the pins correctly. Most dumb assed internet sites do it the other way round.
Jan Suhr
  • Nyköping, Sweden
« Reply #5 on: 29 September 2017, 18:57:45 »
The unit I'm putting in has support for steering wheel buttons. If I can find the correct cable the steering wheel buttons will work. I did this on my other Omega byt then that cable was in pos 5 on the lowest connector where it is empty on this car.
If I can find out which one between 17 - 36 is the steering wheel control it will work on this aftermarket unit.
Here is my post about the other Omega when I got it to work there.
http://www.omegaowners.com/forum/index.php?topic=136202.msg1748266#msg1748266
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #6 on: 29 September 2017, 19:12:01 »
pins 1 and 7
Jan Suhr
  • Nyköping, Sweden
« Reply #7 on: 01 October 2017, 12:55:31 »
Pin 1 worked perfectly.
Thanks
Jan Suhr
Stockholm, Sweden
www.protouring.se
