FAO Tunnie
Started by Viral_Jim, 04 October 2017, 17:56:46
Quote from: TD on 05 October 2017, 17:18:21
Quote from: TheBoy on 04 October 2017, 18:54:10
I couldn't give 2 hoots about economy. If I could, I'd have a small shitbox ;)
Autos always hammer urban mpg...
They do...but in theory they should do better than a manual, as they are always in the right gear....
You'll never be in TC lockup around town, hence inefficient.
Quote from: Doctor Gollum on 05 October 2017, 19:03:07
If by 'always in the right gear' you mean forever changing up regardless of rpm/boost etc... then yes, they're always in the right gear ::)
They also hold the gears longer than you would in a manual, and you can't footle around at 11-1200 revs like I used to in my manual astra. When driving gently, my auto box is always between 1500-2200 and changes up or down between those ranges.
Quote from: STEMO on 05 October 2017, 19:09:15
Paddles?
they're in whatever gear the programmer decided is the correct gear for NOW. But it's a reactive mechanism, so you can't rely on it being in the correct gear at the right time. You can decide to hold onto a low gear for longer than is normal because you judge that it will be needed; an automatic can't.
Quote from: Field Marshal Dr. Opti on 07 October 2017, 11:46:25
Paddles?
Not auto then, is it?
Quote from: STEMO on 07 October 2017, 12:01:01
Paddles?
Yes it is.....manual override of an automatic gearbox.
My car is an 8 speed auto with paddles. :)
Yep..manual override.....not auto.
Quote from: STEMO on 07 October 2017, 14:18:34
Manual override of an 'automatic' gearbox.
The gearbox is automatic.
It's really not that difficult to grasp. ::) ::) ::) :)
Quote from: Field Marshal Dr. Opti on 07 October 2017, 14:53:42
I have an automatic washing machine, I don't take bits out and give them a quick rub mid-cycle.  :)
Migv6 le Frog Fan
Quote from: STEMO on 07 October 2017, 16:41:40
My wife owns a washing machine......and a cooker.
plym ian
Quote from: tunnie on 04 October 2017, 21:40:06
Somehow it's 250% full, I'm clearing it out  :y
Whats that your dpf? Sounds like another vw scandal on the way  ;D
Quote from: plym ian on 08 October 2017, 22:26:02
;D ;D
Don't have a VW any more  ;)
