Author Topic: rear engine oil leak  (Read 2616 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« on: 07 October 2017, 15:52:42 »
I think I have an oil leak from the rear end of the engine. nothing too serious . there is no oil to be seen at the top, or the front of the engine which regions are clean . it appears to be from the rear. guessing its the rear crank seal ( I presume there is one ) which is more of a job to put right than its probably worth. wynns do an oil additive which claims to replenish seals. Any good ??.
ajsphead
  • North Somerset
    • Omega 2.2 DTi estate
Re: rear engine oil leak
« Reply #1 on: 07 October 2017, 19:49:35 »
I have a matching leak, been there for ages, nothing very much. Probably is the rear crank oil seal so I'll sort it out as and when the clutch gives up. In the meantime it serves as light rust proofing which I'm OK with.
Don't trust any oil additives. Risk of compromising oilways and pump, coating things you don't want coated etc too great in my book.
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 08 October 2017, 22:18:24 »
  sounds good advice . if I had decided to do it I would have probably do a clutch change too. the clutches in these seem almost indestructible so could have a long wait,
ajsphead
  • North Somerset
« Reply #3 on: 09 October 2017, 07:39:03 »
Also just remembered that part of the leak was coming from the oil filter housing gasket. Might be worth just checking that too. Clutches are pretty indestructible although I have once got it to slip post remap, very busy roundabout, fully loaded, 1st into 2nd gear bang on boost with a heavy foot. Never again though.
raywilb
    • Citroen C4 Cactus
« Reply #4 on: 10 October 2017, 11:26:00 »
I have had mine remapped along with an egr delete, now no issues. regards the oil filter housing I once ordered from vx the gaskets for the oil cooler & the filter housing & had to buy them in packs of ten. he let me have them at cost so wasn't too bad. if you ever need them pm me & I will send you a set.  :y
ajsphead
  • North Somerset
« Reply #5 on: 11 October 2017, 07:19:47 »
Cheers, will make a note.
