OOF Outage
Started by TheBoy, 08 October 2017, 12:35:38
Cough. That was over 4yrs ago. Ancient history. To be forgotten by all.
Quote from: TheBoy on 09 October 2017, 17:56:31
Of course... I'll never mention it again. Or tree shaped air fresheners :-X ::) :D
Bigron
Quote from: Lazydocker on 09 October 2017, 18:31:12
Punishment will be swift if you do...
biggriffin
Quote from: TheBoy on 09 October 2017, 18:53:05
Mmm newbie docker again
Hoof'land storeman.
Quote from: biggriffin on 09 October 2017, 20:53:43
Probably... Been a while :-X ::)  ;D
Moving the webserver and primary database off the flash storage onto a traditional HDD raid 10 storage device.
There should be no outage (its moving right now), but obviously spinning media is slower than flash, so page load times may increase slightly.
This is to run diags on the flash storage that crashed at the weekend.
Shackeng
Migv6 le Frog Fan
I would have done exactly the same.  :y
;D ;D
Blimey, WTF is happening lately  >:(
One of the hypervisors has sorta crashed, following a minor health alert this morning.  What should happen is if the hardware health is suspect, all the load moves over to another, healthy hypervisor.  In this case its just shat it pants.  The VMs are still running, but unmanageable.
So, no choice but to power cycle the underlying hardware, which will ungracefully power cycle the VMs running on it.
From an OOF prespective, this includes the primary webserver, the primary database, and the secondary database (which affinity rules say should never be on same hypervisor as primary, so something else has gone wrong there).
I shall do this when I finish work today.
Quote from: TheBoy on 16 October 2017, 14:18:50
Good luck, and thank you in advance   :y :y
Panic over - managed to finally get sufficient control of the bastid hypervisor to allow all the VMs to be move gracefully, and then rebooted the hypervisor :)
No outage needed. Happy days.  Sometimes simple victories give me a real smile :)
Lizzie Zoom
Quote from: TheBoy on 16 October 2017, 17:43:29
Does that mean TB your cull is postponed?? :-\ :-\ ;D ;D ;)
TD
You need to upgrade from win95  ;) ;D ;D
Well done TB  :y
Quote from: Lizzie Zoom on 16 October 2017, 17:45:33
No. I'll just be happier executing it.
