Author Topic: Fog tail light  (Read 4783 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Fog tail light
« on: 08 October 2017, 12:47:41 »
My instrument panel shows a fog light warning when car is put into reverse and my reversing lights and fog lights  are not working.This has started after towing the caravan.My owners manual states The fog lights are deactivated when towing a caravan. Has something failed in this process.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Fog tail light
« Reply #1 on: 08 October 2017, 17:42:06 »
Having done some research it looks as if the problem might be a failed relay that is fitted when the tow bar is fitted to prevent glare when towing. Next is rear panel off in boot and find the relay.Fingers crossed.
Muroman
  • Finland
  • Cars for life
    • Vectra -02
Re: Fog tail light
« Reply #2 on: 28 February 2018, 14:58:48 »
Did you find solution? I haven't towed anything in a while but today as normal reversed out of garage and rear fog light indicator went on. However fog light isn't on when it does it. In drive or park everything works normally  ???
Driving: Vectra - 2002 - 2.2 "GTS" - Manual
Old: Omega - 1999 - MV6 - Automatic
Old: Omega - 1995 - MV6 - Manual
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Fog tail light
« Reply #3 on: 28 February 2018, 20:17:18 »
My problem turned out to be a broken wire where the cable runs through the boot lid.Constant flexing takes its toll.
Automaticman
  • Neston
  • Saxwood
    • Frontera V6 Omega V6
Re: Fog tail light
« Reply #4 on: 01 March 2018, 19:50:16 »
Had that once with a Rover Tomcat :-[
When ya wanna shoot, shoot, dont talk !
Muroman
  • Finland
  • Cars for life
    • Vectra -02
Re: Fog tail light
« Reply #5 on: 01 March 2018, 19:56:47 »
I checked those and there it was, Blue/Black was not completely cut but visible copper and Brown was cut.  :y Thanks!!
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Fog tail light
« Reply #6 on: 03 March 2018, 09:13:56 »
Well done I have been of some use at last :y
