Author Topic: Exhaust trim  (Read 4219 times)
Exhaust trim
« on: 10 October 2017, 10:11:58 »
Anyone recently put an exhaust trim on the 3.0/3.2 twin pipes? Due to their being 2 pipes being close together some may not fit side by side  :-\
The Zafira has a nice little Chrome trim (from the factory) which makes it look nice. Always thought the eternal exhausts are good value, but don't look great...
TD
  • Swindon
    • Nowt!
Re: Exhaust trim
« Reply #1 on: 10 October 2017, 13:15:40 »
Those tail pipes don't look round to me, bit of a lip at the top of them.....somebody reversed into a high kerb, perhaps  :-\ ::)
TD
  • Swindon
    • Nowt!
Re: Exhaust trim
« Reply #3 on: 10 October 2017, 13:34:33 »
Used a block of wood on end pipes to wack it onto he centre pipes, when fitting.
Re: Exhaust trim
« Reply #4 on: 10 October 2017, 13:35:40 »
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: Exhaust trim
« Reply #5 on: 10 October 2017, 13:44:03 »
How about something like this.....if it fits  :-\
https://www.amazon.co.uk/XtremeAuto%C2%AE-Stainless-Steel-Twin-WLW1-BW272/dp/B073FPG94R/ref=sr_1_35?s=automotive&ie=UTF8&qid=1507638107&sr=1-35
Humm. Looks nice but unclear on how it bolts on  :-\
If they're anything like the ones on SWMBO's Kuga then there is a single screw which clamps it onto the exhaust.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Exhaust trim
« Reply #6 on: 10 October 2017, 21:53:10 »
Last time I changed the tailpipe on my 3.2, I fitted a Bosal system. The old tailpipe was one of the OEM originals with the angled stainless tips which were held on by two blobs of weld. I ground the welds off to remove the tips, and then slid them over the new tailpipe using some plastic metal to hold them in position. Were still on when I sold the car. Only trouble is, not many cars these days still have the original GM tailpipe with the stainless tips on......
« Last Edit: 10 October 2017, 21:55:24 by johnnydog »
annihilator
  • Wirral
    • Omega Tourer V6
Re: Exhaust trim
« Reply #7 on: 12 October 2017, 10:11:27 »
Original GM in the UK never had chrome tips early pre -facelift had gloss black though.
Re: Exhaust trim
« Reply #8 on: 12 October 2017, 10:43:24 »
Yes they did  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Exhaust trim
« Reply #9 on: 12 October 2017, 10:51:10 »
I got a pair of cheap ones off ebay for about 15 quid a couple of years ago.
Yes they are a bit tight together but a piece of wood between the pipes to spread them about a 1/4 inch did the trick.
They are held on with a small self tapping screw which bites up against the exhaust but I recommend you drill a small pilot hole and insert a slightly larger screw or you can bet your life one of the buggers will fall off  :-X :-X
Also its not worth spending stupid money because due to the salt and crap on the roads, it will rust so just replace when they look shit  :y :y
Re: Exhaust trim
« Reply #10 on: 12 October 2017, 10:56:28 »
Agreed, just want to tidy the back end up a bit. Actually bought some for the VW but I never used, they are a little loose. But I think I'll use these and just drill a small hole as you say.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Exhaust trim
« Reply #11 on: 12 October 2017, 12:05:32 »
This thread reminded me that I also want a pair of trims. Ive just been out and done a bit of measuring with a digital caliper.
Diameter of pipes on mine is 50.5mm and the gap between them is 12mm.
Might be of help ?
Re: Exhaust trim
« Reply #12 on: 12 October 2017, 12:33:57 »
Might be of help ?
Cheers  :y
Eternal/ETS on yours?
Migv6 le Frog Fan
Re: Exhaust trim
« Reply #13 on: 12 October 2017, 13:49:04 »
Not sure tbh. It was put on the car just before I bought it.  :-\
johnnydog
  • Lancashire
Re: Exhaust trim
« Reply #14 on: 12 October 2017, 22:51:10 »
Yes, you are absolutely correct about original GM never having chrome tips.
The original OEM tailpipe tips were actually stainless steel.
Page created in 0.029 seconds with 20 queries.
