Author Topic: Electrical issue  (Read 7042 times)
valliant1972
  • UK
    • omega 2.5 v6 cdx
Electrical issue
« on: 14 October 2017, 18:51:17 »
Hi, got a weird issue with my V6...driving along the revs wouldn't settle at idle, then dash lights dimmed then all the warning lights started coming up then it died......after battery was dead. Called for recovery they came out and its started again..tested the alternator and was giving over 13volts. Had it recovered to home, went down it started then I put the lights on and all the warning lights came up, msg on the display said fld vision something went off too quick. then died. So I'm at a loss where to look. All terminals are clean and connected tightly.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Electrical issue
« Reply #1 on: 14 October 2017, 19:19:20 »
Including the earth strap to the engine?
valliant1972
  • UK
    • omega 2.5 v6 cdx
« Reply #2 on: 14 October 2017, 19:46:06 »
Where is the earth strap situated....thanks
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #3 on: 14 October 2017, 19:55:47 »
Nearside, bottom off the engine, near the front corner of the sump and A/C/compressor. Runs across to the chassis from there.
valliant1972
  • UK
    • omega 2.5 v6 cdx
« Reply #4 on: 14 October 2017, 20:02:25 »
ok thanks.....will give it a look. Does it sound like anything else I should be looking at?
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #5 on: 14 October 2017, 23:23:54 »
Alternator bearings failing would be my guess, cure is to change the alternator.
« Reply #6 on: 15 October 2017, 08:44:28 »
Alternator bearings failing would be my guess, cure is to change the alternator replace the bearings.
Fixed that for you  ;)
Could be the alternator bearings (although that's a fair way down the list for me), could be the brushes in the regulator, could be a bad connection either at the battery (terminal crimps have a habit of failing) or one of the many earth straps.
There's a really good guide in the maintenance section for checking the charging system.
« Last Edit: 15 October 2017, 08:46:00 by Lazydocker »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 15 October 2017, 12:31:08 »
had similar it was the alternator
Boatboy
  • St Albans
« Reply #8 on: 15 October 2017, 12:53:10 »
Similar symptoms for me a couple of months back caused by alternator regulator.
I got a replacement from unit exchange in borehamwood for about £35. Not the cheapest advertised but theyre only 1/2 hour away and I needed it asap.
They took a new reg off a stock alternator for me.
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
valliant1972
  • UK
    • omega 2.5 v6 cdx
« Reply #9 on: 15 October 2017, 15:41:31 »
Thanks for your replies. will look into what has been suggested
valliant1972
  • UK
    • omega 2.5 v6 cdx
« Reply #10 on: 15 October 2017, 19:00:36 »
Got the car started. Put a voltmeter across and got 11.84 volts. so looks like the alternator bit the dust.....but still cant find the earth strap. Looked all around the a/c side and the alternator side. Does anyone have a picture or diagram? Thanks
terry paget
    • 3 Astras 2 Vectra
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
valliant1972
  • UK
    • omega 2.5 v6 cdx
« Reply #13 on: 15 October 2017, 20:35:46 »
Sorry was asking where the Earth strap is cause I cant find the location....was suggested where the A/C pump is but cant see it. So wondered if there was a picture or diagram. Thanks Terry but that is a starter motor.
terry paget
    • 3 Astras 2 Vectra
« Reply #14 on: 15 October 2017, 22:49:32 »
Quite right, that is a starter motor. I wonder why it is being sold as an alternator.
