Author Topic: Rear discs.  (Read 5698 times)
Re: Rear discs.
« Reply #15 on: 17 October 2017, 17:45:18 »
Wire brush it up  :y
I did that, then compare the lip with that indent, for me it meant I had miles left on the discs and stuck new pads in.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Rear discs.
« Reply #16 on: 17 October 2017, 17:49:07 »
Does anyone use the indent in the side of the disc? You know that grooved but which shows how far it can wear down?
eg:
Aren't they to balance the disc? Every worn disc I've ever changed has had a ridge around the perimeter, not extra wear.
Re: Rear discs.
« Reply #17 on: 17 October 2017, 18:04:25 »
Pmsl ;D
That is machined in to balance the disc...
Minimum thickness is stamped on the outer edge, and is typically 1-2mm less than the nominal thickness...
In the case of the Omega, this is 18mm iirc :y
Re: Rear discs.
« Reply #18 on: 17 October 2017, 18:07:09 »
My mistake, thought it was wear indicator. But I bet that grove is not far off 18mm,
Re: Rear discs.
« Reply #19 on: 17 October 2017, 18:09:10 »
If that's a 20mm disc, the pads would drop out by that point as there's about 14mm of disc left ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Rear discs.
« Reply #20 on: 17 October 2017, 18:53:47 »
Pmsl ;D
I said he wouldn't let me down.  ;D
Thanks DG. :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Rear discs.
« Reply #21 on: 17 October 2017, 19:09:35 »
Try your local factor for a price, or even car parts for less, bound to be a code.
Hoof'land storeman.
Re: Rear discs.
« Reply #22 on: 18 October 2017, 19:00:48 »
Its a long way off - a disc cannot sustain that amount of wear, as they would become too weak.
