Author Topic: Puddle Light - Door Switch?  (Read 3105 times)
« on: 19 October 2017, 20:52:32 »
Only noticed today, as it's getting dark. But the passenger door puddle light works fine when I open the drivers door, but open the passenger side and it no worky.
I know they get stuck some times, so manually activated it a number of times, no joy  :(
Faulty door switch?  :-\
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Puddle Light - Door Switch?
« Reply #1 on: 19 October 2017, 21:06:48 »
Bulb ?
« Reply #2 on: 19 October 2017, 21:27:46 »
Bulb ?
Migv6 le Frog Fan
« Reply #3 on: 19 October 2017, 23:04:00 »
I didnt read it properly.  :-[ ;D
« Reply #4 on: 19 October 2017, 23:06:57 »
If memory serves,  the switch actually "earths" the supply rather than providing power .. so if the "other" door opening provides the earth I would check the connection between switch and chassis on the passenger side ....
« Reply #5 on: 19 October 2017, 23:16:15 »
Thanks, I'll pop it off and check it's all good.
« Reply #6 on: 20 October 2017, 14:23:13 »
So kind-of fixed this, nipped out to the car earlier and took another look. Just gave the push switch a wiggle while in place, and it started working.
So clearly bit dirty/corroded under the rubber cover, so back home will whip this off and clean it.
« Reply #7 on: 20 October 2017, 18:22:33 »
Same switched used for other things, such as courtesy light and alarm, so surprised not noticed before.
You may well find that cleaning is only a short term solution, so might be worth having one on standby :)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #8 on: 20 October 2017, 18:47:04 »
Contemplating changing my standard Festoon puddle lights to LED / SMD ones  :-\
  • Anybody done it ?
  • Any preference to length of bulb ? (I get a few different answers the more I look !)
  • Any preference to sellers and suppliers ?
Thanks
Andy.
Lincs Robert
« Reply #9 on: 23 October 2017, 18:05:02 »
  • Anybody done it ?
Thanks
Andy.
I tried it and reverted back again.  :(
