Another internet problem.
Started by TD, 21 October 2017, 17:09:57
omega2018
Quote from: TheBoy on 25 October 2017, 19:42:59
Quote from: migmog on 24 October 2017, 00:34:36
Quote from: Mr Gav on 23 October 2017, 13:08:26
A brief report of Rapport, I have read elsewhere that it isn`t good.
only problem i have seen with rapport is occasionally they lag behind Chrome releases resulting in rapport not protecting a bank login page as it should.  never seen it cause a problem itself.
unlike some of the products the site in that link promotes eg Avast! >:(
Class yourself one of the lucky few.
The majority of the major UK banks still recommend IBM's Rapport :y.
Quote from: migmog on 25 October 2017, 20:36:04
And that's not based on technical reasons, but commercials.  Think along the lines of "we'll give you a discount on your shiny Z series hardware support if you get our shitty software on millions of devices"
Rapport is known to be problematic. Trust me on this ;)
Just because I recommend some boil their heads, that doesn't mean they should.
omega2018
Quote from: TheBoy on 26 October 2017, 09:48:35
that would make sense if all the banks that recommend IBM rapport used IBM hardware.  they don't.
Barclays recommend the Ruskies  :o
Quote from: migmog on 26 October 2017, 12:52:40
That was an example. Bloody hell you are hard work.
OK "we'll give you $1m to shove our shit on plebs PCs, as you don't use any of our hardware, software, or support (unlikely)"
Viral_Jim
I've never installed Rapport, or any of those other bobbins bits of security. What is it supposed to do that simply operating over https does not?
Quote from: jimmy944 on 26 October 2017, 16:18:52
It performs client-side inspection; looking for keyloggers, browser hooks etc etc, which HTTPS means nought to - it's no good securing the data in-transit if it's already been stolen when it was at-rest :) https://krebsonsecurity.com/2010/04/a-closer-look-at-rapport-from-trusteer/
There are other solutions that require no client-side install, but they are more complex for the site owner to implement (disclosure: I work for a company selling one such solution) as they require tight integration with the site itself rather than a "drop in" client side application.
So to simplify it, most products are mere fences, where as what you offer is more of a custom bunker with the core system integrated into the very fabric of it...
omega2018
Quote from: aaronjb on 26 October 2017, 16:33:00
thanks its nice to see a link here that is reasonable and rational and not FUD. :y
Quote from: Doctor Gollum on 26 October 2017, 16:40:55
When you get down to it all security products are really just fences of differing heights.. some are 3' chain link, some are 18' concrete, but given sufficient time and resources and attacker can (and will) get past any of them ;) (especially if they're nation state!)
I was using some of "your" products, still in their boxes since you shipped them nearly a year ago, as a table and a step ladder the other day.  Most expensive table I've ever used as a step ladder ;D
As you know, but others may not, if you control the client, you can do what you like in the middle - including on the fly decryption of https. And redirection of all traffic, encrypted or otherwise  :-X
Quote from: aaronjb on 27 October 2017, 14:06:24
Absolutely.  Although these fences often conflict with one another, in the same way running 2 AV solutions can trip up (and REMOVE!!) the other.
Rapport is seen to be too buggy and inconsistent to be recommended by most independent consultants.  Mind you, Kaspersky is also going through a bad time at the moment, with constant rumblings that won't go away that the Russian authorities have code in there to give back door access.  And Symantec as well, given their business' of SSL certificates (through subsidiary Verisign) and border inspection (subsidiary Bluecoat), and "accidentally" signing Bluecoat's scanner's internal intermediate certificate - meaning a Bluecoat scanner can decrypt any PKI encrypted traffic, including https, irrespective of the client trusting Bluecoat (now Bluecoat claim that has never been sent outside of its test labs, but I suspect that the large US authorities have the capability)
In other words, if you want it to be secure, use this envelope and a stamp. :y
Quote from: Kevin Wood on 28 October 2017, 10:24:25
Not really, as that's susceptible to MiM as well.
Deliver by hand ;)
omega2018
Quote from: TheBoy on 26 October 2017, 15:58:56
That was an example. Bloody hell you are hard work. Bloody hell you don't always agree with every precious word I say
fixed that for you :y
