Author Topic: Daughter has locked herself out of car with engine running  (Read 9407 times)
Re: Daughter has locked herself out of car with engine running
« Reply #15 on: 25 October 2017, 22:46:36 »
...... Over the last twenty years, manufacturers have made cars much harder to open. Which considering how easy it used to be was overdue.
My Cortina could be opened & started with anything that resembled a key  ;D ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #16 on: 25 October 2017, 23:21:43 »
Had an Mk 2 Grannie, some numpties tried to get in and failed. God, they must have been thick. ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17 on: 25 October 2017, 23:33:22 »
my £25 Cortina wasn't too bad, as it hadn't done many miles. Most of my Capris were a different story ::)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
« Reply #18 on: 26 October 2017, 12:14:00 »
when alls done & your daughter  is in. why not get a key cut even if its not programmed just keep it in her handbag, when I bought my present mig it came with 2 programmed keys & a blank which was cut so it will get me in,
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #19 on: 26 October 2017, 12:24:27 »
i keep a spare key permanently in/on the car, in a hidden place that can be accessed in emergency, with a little effort (but less then bending the door). main purpose though is to be able to drive the car if i lose my normal key.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #20 on: 26 October 2017, 13:59:23 »
Handbag was in the car, as was her RAC membership card, her phone, in fact everything she might have needed. Solution might be have spare key in a magnetic box somewhere under the car.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #21 on: 02 November 2017, 22:05:47 »
I know it's a bit too late now but this works I had to do it myself. Surprisingly easy!!
                      https://m.youtube.com/watch?v=XWVNWn9BpQ4
Laying a rubber road.
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #22 on: 02 November 2017, 23:19:37 »
You mean that works on the tapered Omega door buttons?
Ron.
Raeturbo
  • South Wales
« Reply #23 on: 06 November 2017, 21:15:32 »
Worked on my 03.... 2.2 petrol?? They got them ?.
neil74
  • newport
    • 2.6 elite estate.
« Reply #24 on: 06 November 2017, 22:00:58 »
I used to have a MK2 escort that was rotten in the area where the window frame was welded to the shell of the door so all you had to do was pull the frame out like a 2CV and unlock it..
Mike1962
« Reply #25 on: 27 November 2017, 18:50:28 »
I double locked myself out 2 years ago! Locked keys in the boot!
Took AA 1 1/2 to get in!
Ended up prying the boot and putitng a charge to the boot lock wires. Took 5 mins once he figured out how!
