Author Topic: New Exhaust - Just want to check before I leap in !!!!!!!  (Read 18806 times)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« on: 27 October 2017, 15:50:15 »
Hi all,
Looking to put new exhaust on the old girl (took her for a spin today and noticed a slight blow, and MOT next month).  Also, last exhaust was 10+ years ago (or longer I think !) and was a GM one !, and somebody said I had a horse tail following me the other day at work as I cruised around the car park  ;D
Remembering previous discussions on exhausts from this forum, I assume I am correct in assuming:
  • The ETS / Eternal one on E.bay (Clamshell) is still a good buy ? - £90 for full system ?
  • GM one was pretty quiet.  Assume the ETS one is similar - Not want a tinny sounding thing  :(
  • I have the MFL 2.5V6, but fancy the twin tailpipes - I understood the 3.0V6 one will fit exactly same with the twin tailpipe back box?
  • Is it a DIY job ?
  • Any tips before I attempt ?
  • Do I need any type of paste when making all connections on the system ?
  • I have ordered 4 new bolts from the stealer - Is this a good idea ?
  • Considering a Chrome tail (Nothing obscene, just a small detail finish  :)- Good idea or leave alone ?  any recommendations if others have used.
Thanks in advance all,
Andy.
Re: New Exhaust - Just want to check before I leap in !!!!!!!
« Reply #1 on: 27 October 2017, 16:04:02 »
Hi all,
- Yup
- As close as you will get to GM for the money.
- Yup
  • Is it a DIY job ?
- Yup, just a hassle as the bolts often corroded and you have to drill the buggers out. Consider dropping cats/downpipes to work on a bench
- Plusgas the bolts where Zorst bolts to cats.
- Holts Hot Gum stuff or similar for paste on cat flange
- Not sure how good quality dealer bolts will be
- All down to your personal choice
[/list]
Andy.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 27 October 2017, 16:11:40 »
I usually use household silicone when joining backboxes to pipes i.e. any sleeved joint, it works a treat
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #3 on: 27 October 2017, 19:09:45 »
Personally I'd go with chrome/stainless tips I just think they give that final finish to the exhaust.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #4 on: 28 October 2017, 08:23:51 »
Big problem is removing the screws attaching centre section to downpipes. If you break them off, drilling out the remains is a rotten job. I always heat the downpipe ends/screws to red heat with a blow torch before attempting to unscrew them, then do it gingerly.
jb
  • bucks
    • 3.2 Elite
« Reply #5 on: 28 October 2017, 09:15:48 »
Have had many eternal car systems as good or better than GM. tWIN PIPE 3.0 BOX A DIRECT FIT. Not really a diy job if your old one been on for 10 yrs...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #6 on: 28 October 2017, 10:06:41 »
Had couple of, ets systems very good fit comes with all the fittings and new rubbers, go and buy a set of good 5/16\ 8mm drill bits, and some 4mm bits, a tube of general purpose black silicone.for the joints,
Remove exhaust, drill out the flanges on new system to 8mm, drill old studs out of down pipes, 4mm, then 8mm, hang centre sections, using new rubbers, loosely fit new nuts n bolts, fit rear silencer, tighten bolts, then align rear box and tighten clamps.
Hoof'land storeman.
« Reply #7 on: 28 October 2017, 10:45:10 »
The sound from ETS/Eternal is similar to old school GM, and miles, miles better than the god awful Bosal etc fitted by most fast fit places.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 28 October 2017, 11:55:36 »
Rubbish!
If the downpipe to system bolts undo, then it's a 40minute start-to-finish job, on your own, in the street.
If using a DIY drill add 10minutes per bolt that doesn't undo. Replace with a longer bolt and nut. If you have oxy-acetylene, heat the stub of the bolt to cherry red and punch the bastard thing out - 1minute plus however long it takes to get the tools out.
This is a job where DIY not only makes sense, but is to be recommended.
« Reply #9 on: 28 October 2017, 14:32:56 »
As long as you don't cut your face open with an angle grinder ::) :-X
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #10 on: 28 October 2017, 15:21:13 »
Rubbish!
It soundsso easy when its put like that - by a professional mechanic.  :D
  • Chatham, Kent
« Reply #11 on: 28 October 2017, 16:41:43 »
Rubbish!
It sounds so easy when its put like that - by a professional mechanic.  :D
If the four M8 bolts holding the system to the downpipes undo, you remove the entire system with nothing more than a Stanley knife through the mounting rubbers and letting gravity move it to the floor. No skills required, unless you feel the need to make things difficult ::) . You then loosely bolt the new silencers in place, hang each of them from their rubbers, knock the rear silencer onto them, hang it from its rubber and do up the loose bolts having ensured that nothing is touching the bodywork. That's only difficult if you're using a poorly made system that doesn't line up; the ETS fit perfectly so aren't a problem.
    • 530D M Sport, 330i Coupe
« Reply #12 on: 28 October 2017, 16:56:57 »
Rubbish!
If the original mounting rubbers are GM and are good condition then re-use them rather than using the ones that come with the ETS kit as they will be stretched and splitting around 18 months - 2 years. Strangely the rubbers ETS supply with the exhaust for an Alhambra / Galaxy / Sharon are far better quality.
« Reply #13 on: 28 October 2017, 17:17:52 »
Rubbish!
Whilst I agree that DIY is nearly always the way to go, if those bolts shear, its rarely "10mins per bolt", only if you're really lucky.
The last one I did took 22 bits to drill just one of the bolts out (they other 2 drilled out much better)...
  • Chatham, Kent
« Reply #14 on: 28 October 2017, 17:24:57 »
That's not my experience; mine have been on there three years(might be four :o ) with no problems. I HATE messing about with exhausts, and my procedure is simple: replace everything, at the same time, with new.
Pages: [1] 2 3 4  All   Go Up
Page created in 0.022 seconds with 20 queries.
