Author Topic: Naughty, naughty  (Read 17112 times)
Re: Naughty, naughty
« Reply #15 on: 30 October 2017, 09:21:21 »
The fault lies with the manufacturers of DPFs; they need to make a device that is fit for purpose and will not clog up so readily - or at all!
Once again, the cost/blame has been passed on to the motorist.....  >:(
Ron.
It is fit for purpose (as I can confirm having stuck 194k miles on one with no issues)
The issue is those who insist on having a modern diesel for plodding about in.....there not up to that and cant be used for that.  :y
« Reply #16 on: 30 October 2017, 09:22:31 »
When buying a car, how do you know if the DPF has been gutted or not?  :-\
Not something Lord Opti needs to worry about of course, but for us mere mortals who like to get 40+ mpg.  :)
It will smoke when booted (not massive amounts but will be visible), with a DPF they only smoke on regen
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #17 on: 30 October 2017, 10:05:33 »
Until next year it could be tricky, other than the snide Mr Fuse points out. However it's not really much different to a knackered CAT in a petrol car. Wouldn't know about that until mr MOT man hands you a fail slip.
Potential recourse to the dealer I guess if purchased within 6months of the problem being identified.  :-\
« Reply #18 on: 30 October 2017, 11:03:57 »
You don't. You get to play Russian roulette with your bum virginity ;)
« Reply #19 on: 30 October 2017, 11:48:15 »
There aren’t many bum virgins on here  ;D
« Reply #20 on: 30 October 2017, 11:54:22 »
Speak for yourself. :o
« Reply #21 on: 30 October 2017, 12:51:47 »
The male bum is designed and should be for 'exit only'
The female rump however .......... ;)
« Reply #22 on: 30 October 2017, 13:18:43 »
I guess a visual inspection, see if the it's been buggered about with underneath. Can't exactly do that when viewing cars though!
« Reply #23 on: 30 October 2017, 13:19:46 »
That said with VAG you could do a plug in and insect the DPF's condition via software... as sure you can on others. But do need the specialist software to do it
« Reply #24 on: 30 October 2017, 15:01:39 »
I doubt many dealers would be happy if you turned up with your trolley jack, nor would they let you plug in your gizmo.  ;)
« Reply #25 on: 30 October 2017, 15:21:35 »
Trouble is, most of the software mods frig that specific number to force the ECU to not regen  :y
« Reply #26 on: 30 October 2017, 15:34:24 »
Great, so can't confirm that either. So it gives false readings for back pressure and soot?  :-\
So i guess the only other way to look would be soot around the tail pipe, as DPF functioning should mean a diesel has a very clean tail pipe.
« Reply #27 on: 30 October 2017, 15:44:37 »
Boot it hard and look in the rear view mirror.
Saturation is calculated from back pressure and its the saturation that triggers a regen
« Reply #28 on: 30 October 2017, 17:41:52 »
What on earth achieves that :o
« Reply #29 on: 30 October 2017, 17:51:22 »
I said we like to get 40+ mpg.  :)  Whether we achieve 40+ mpg is another matter!  ;D
That said my trip computer on the Mondeo was showing an average 48 mpg the other day when I tried.  :y
