Author Topic: fitting saab engine  (Read 4673 times)
Lawson
  • Ballynahinch
    • mv6
fitting saab engine
« on: 30 October 2017, 19:35:18 »
any help/advice on fitting Saab turbo engine especially how to get the ECU and clutch to work
Thanks
GrahamT
  • Rhyl
    • Omega/Calibra/Manta
Re: fitting saab engine
« Reply #1 on: 30 October 2017, 22:34:57 »
Thanks
Which SAAB engine are you trying to fit and to what model omega?
If you get the right year engine it will bolt straight up to the Omega manual gearbox.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 31 October 2017, 13:45:35 »
I believe a Vectra clutch with a 20mm spacer is required
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 01 November 2017, 22:21:40 »
Thanks
B204/b234 bolt straight to omega gearbox Saab flywheel and pressure plate and omega clutch plate
You can buyou on line adapter kit
BTW I have almost complite kits for sale
Lawson
  • Ballynahinch
    • mv6
« Reply #4 on: 01 November 2017, 23:05:19 »
thanks for the replies
 its a B204 engine and I have a V6 box from a 3L MV6
any more info on the adaptor kit would be helpful ie what does it consist off?
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 02 November 2017, 21:50:03 »
Basically you keep Saab engine loom then use adapter to plug to your car
Think there 7 wires
If you on fb then have look on vauxsaab
serek
  • huntingdon
    • 3.2 mv6
« Reply #6 on: 02 November 2017, 21:51:34 »
What you going to do with oil sump? Any idea?  As one from FWD not good for omega , oil starvation straight away
Page created in 0.025 seconds with 20 queries.
