Mrs TB 1, TB 0
Started by TheBoy, 01 November 2017, 18:36:00
biggriffin
Quote from: Jimbob on 02 November 2017, 12:28:35
Heating?  Im still in shorts!
Me too.   Wifey keeps putting a coat on?????
Hoof'land storeman.
TD
Ive had the heating on in the evenings since mid September!
This week tho as its got colder ive turned the timer on so it comes on in the mornings as well ....
biggriffin
Quote from: TD on 03 November 2017, 07:42:26
Ya big woosie. Man up
Hoof'land storeman.
Quote from: biggriffin on 04 November 2017, 09:47:26
exactly. If you put the heating on when the temperature is still a pleasant 10°, what will you do when it becomes a bit chilly at freezing?
I did wear a coat last week, but it was raining when I left the house.
biggriffin
Quote from: Nick W on 04 November 2017, 10:13:09
I hope it was only a lightweight shower proof jacket (kagoul) type. Not a full on winter type.
Hoof'land storeman.
TD
Ummm nothing....the boiler will just work harder getting the room temp to 21c  :y At the moment it just ticks over using very little gas...
Quote from: TD on 04 November 2017, 16:14:23
my point was that rather than acclimating to the gradually cooling autumn weather, you're setting yourself up for feeling cold whenever you go outside for the rest of the winter
TD
Quote from: Nick W on 04 November 2017, 17:27:47
More than likely....but being diabetic I feel the cold....and like to be warm  :y
Shackeng
We had to replace our 35 year old double glazing recently and fitted triple glazing for only 8% more than double. At the same time we insulated our living room with these http://www.ecotherm.co.uk/our_productscavity_wall_insulation_which_provides_maximum_insulation_with_the_minimum_of_thickness/eco-liner.aspx and my heating bills have dropped, considerably. Difficult to assess exactly how much as SWMBO requires more heating at her age, but I am still paying less than previously. :y
BazaJT
Well someone must be a expecting a bit of a chill,as I've just been out with the dog[despite the fireworks]and been passed by two gritting lorries spreading their salt :o
TD
Quote from: Shackeng on 04 November 2017, 18:30:09
You've a '/' missing....
Should be .....
http://www.ecotherm.co.uk/our_products/cavity_wall_insulation_which_provides_maximum_insulation_with_the_minimum_of_thickness/eco-liner.aspx
Shackeng
Rods2
I believe in equality, while SWMBO decides the cooking time and heat setting, I decide the central heating ones. :y :y :y
