Author Topic: Dodgy Volkswagen  (Read 3286 times)
FRE07962128
Re: Dodgy Volkswagen
« Reply #15 on: 09 August 2008, 13:16:00 »
Errr No........
Nice to see you again Kate  :y
But a blowing exhaust doesnt cause missfires......
I beg to differ, a faulty centre exhaust can cause rough running that may feel like a missfire, I experienced this some time ago on a Matra Ranho. As soon as I replaced a length of centre pip it was fine again.
Nice to hear from you again Kate :y
Glad you said that Mike, as I seem to remember a u/s exhaust on one of my cars causing bad performance / misfire seemingly.  ;)
I am sure that a faulty exhaust does change the pressure balance of the engine and effectivly "choke it" by back pressure and thus effect the firing of the engine. :-/ :-/
As for the Cat question Kate, if I recall correctly most cars, if not all, HAD to have cats fitted if registered after about August 1992.  I know that my 1990 Senator, and those registered up to July 1992, were the last were if I wanted to I could have erradicated the cats and still passed the MOT. ;)
Your Polo therefore I am pretty sure will have a Cat fittied. :y
« Last Edit: 09 August 2008, 13:16:57 by FRE07962128 »
« Reply #16 on: 09 August 2008, 17:04:16 »
A very common failure on those is the coil... Really easy job but bl00dy expensive part  >:( >:( >:(
Have someone with a coil tester check it for you... Most places will do that for free :y :y :y
As a word of warning... If it is the coil failing it may not give you much warning before it dies completely :o :o :o :o
Sorry to put the frighteners on there but wanted to warn you :y :y :y
Nice to see you again Kate... Keep smiling ;) ;) ;) :y :y :y
Kate
  • Cornwall
    • Drives people mad
« Reply #17 on: 09 August 2008, 19:53:54 »
Thanks for all your help.  I'm sure I'll get it sorted out now. :y
