Author Topic: Fault Code 2106  (Read 8330 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Fault Code 2106
« on: 02 November 2017, 16:20:44 »
Ive the Following Codes, spanner light on.
0650
2106
1612
3.2, been stood for a while, new battery, fired up first time, no issues, then after a min or 2 starts to stutter, initial thoughts was missfire, restarted, fine then stutter again, go to pull away drops revs, almost like fuel starvation.
Peddle tricked for codes, I think the 0650 may be one of the bulbs is out (airbag?), googled code 2106, comming back as generic, Throttle / Peddle Sender? Is this the case for Omega?
Car now wont start, it does but ticks over low then stalls, any effort on the throttle stalls striaght away. Going to consetrate on this fault first but where to start???, help pleasd.
Code 1612 could be a red herring as batt now low (no flashing Spanner).
Re: Fault Code 2106
« Reply #1 on: 02 November 2017, 18:08:05 »
Not received a status update from TCM for over 10s
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #2 on: 02 November 2017, 18:38:52 »
Ok thanks, so what to look for?, plugs / connectors around peddle and TB's, anything else, any part testing I can do?
Anyone had this before, and what was the outcome?
Ta.
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #3 on: 02 November 2017, 18:40:37 »
Would it be worth swapping over the TB's for a known good one, 3.2 and 2.6 are they the same?
Re: Fault Code 2106
« Reply #4 on: 02 November 2017, 18:42:24 »
Nothing to do with TB. Its TCM. Is it an auto?
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #5 on: 02 November 2017, 18:43:21 »
No 3.2 Manual,
Re: Fault Code 2106
« Reply #6 on: 02 November 2017, 18:46:29 »
No 3.2 Manual,
Well that's your problem. Find a local Tech2, and set ECU config back to manual :)
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #7 on: 02 November 2017, 18:46:50 »
No 3.2 Manual,
But.... Im trying think,....  did I I borrow the ECU same time back to prove an ECU issue on an Auto? and not put it back, either way it was running fine untill today  :-\.
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #8 on: 02 November 2017, 18:49:38 »
No 3.2 Manual,
I take it you mean Engine ECU, if so thought they were Auto / Manual from a High / Low (Loom) pin on the ECU
Re: Fault Code 2106
« Reply #9 on: 02 November 2017, 19:11:29 »
No 3.2 Manual,
Yes, Engine ECU, ie ECM.
Not sure that's the case on the CAN ones. I'd bow to your expertise on that one TBH, regarding the loom mod.
But U2106 is basically it hasn't spoken to the TCM for a few seconds (and presumably it was expecting to).
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #10 on: 02 November 2017, 19:23:26 »
So, if I borrow ECU (Ring & Trans' Chip) from another Manual that should prove the fault ?
Edit:, actually not too sure about the Loom High Low thing on the 3.2, I know it was the case on the 2.5 and 3.0, so yea, maybe a ECO config, problem is I seem to have gone brain dead today, memory's been erased  :-[
« Last Edit: 02 November 2017, 19:28:13 by zirk »
Re: Fault Code 2106
« Reply #11 on: 02 November 2017, 19:37:00 »
yup, ecu swap should prove that
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #12 on: 02 November 2017, 20:08:28 »
Ok, Thanks TB, job for tomorrow then as other Car is about 20 miles away.  ::)
I'll post up the results
serek
  • huntingdon
    • 3.2 mv6
Re: Fault Code 2106
« Reply #13 on: 02 November 2017, 20:28:01 »
I know sound odd but try disconnect maf sensor
I had 4 or 5 omega 3.2 with same issue
Car start and tick over but won't rev
zirk
  • Epping Forest
Re: Fault Code 2106
« Reply #14 on: 02 November 2017, 20:47:28 »
Will try that Serek before swapping ECU's
Dziękuję
