Head gasket (one of them) - oh well
Started by woolley11, 04 November 2017, 20:53:36
woolley11
No it's parked up with battery off
Waiting investigation
As soon as temp light came on i switched it off
Get my compression tester out next week
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
zirk
So what caused the temp light to come on then?
woolley11
Well what I meant was didn't running the engine once the warning light came on 😉
Omega 3.0 MV6 pfl
woolley11
Done compression test today on the MV6.  :-[
All N/S bank of 3 giving 10/12 bar which is good
The O/S bank - no 1 cylinder ? (nearest the front) only giving 7 bar with nos 2 and 3 cylinders giving around 10 bar.
Also all spark plugs on O/S bank are sat in and covered in oil.
Emulsification of the oil too. The car has been used quite a bit prior to going poorly so can't put it down to its lack of use.
O/S Head gasket then as feared - but will replace cambelt, thermostat and transfer pipe while "in" there.
Job for new year anyway - no time before Christmas unless I get someone to do it for me but in East Yorkshire and not sure of any Vauxhall specialists in near vicinity.
Would it be sensible to replace N/S head gasket while car in bits or leave well alone and the assumption if ain't broke....
Omega 3.0 MV6 pfl
Quote from: woolley11 on 02 December 2017, 14:39:45
Seriously?
considering the amount of dismantling necessary to change V6 head gaskets, what possible reason would you have to change just one? When I did mine, the driver's side gasket was rotten and leaking into the combustion chamber(no, I'd not seen that before either). The passenger side wasn't leaking, but it was in very poor condition.
