Author Topic: headlight position  (Read 2242 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
headlight position
« on: 10 November 2017, 20:08:19 »
after a prang & having put on a bumper the plastic trim underneath the doesn't fit .  I have noticed the headlight seems to be to far in on the side that's next to the grill, when I measure with a steel rule from a point on the washers to the lens there is a 20mm + difference to the other h/l. I got the reinforcing with the brackets attached so that's ok. so I guess the H/L needs to come forward a tad with the lens tilted forward. just how I'm not sure.
Re: headlight position
« Reply #1 on: 10 November 2017, 20:48:59 »
By pulling the slam panel assembly back into alignment  ::)
raywilb
    • Citroen C4 Cactus
« Reply #2 on: 10 November 2017, 21:20:46 »
  do you mean the bar behind the bumper , if you do all the pushfit rivet holes met up as they should including those 3 underneath. when the bonnet is shut at the wing side its ok but at the bonnet side the lens seems to dip in & ends up behind the line of the bonnet
« Reply #3 on: 10 November 2017, 21:39:14 »
No, I mean the slam panel...
You will find that the vertical portion adjacent to the radiator is creased where it is welded onto the inboard edge of the chassis rail...
About 2" down from where the inner edge of the headlight rests against it
« Last Edit: 10 November 2017, 21:43:48 by Doctor Gollum »
