Author Topic: Zafira: LED interior lights  (Read 6360 times)
« on: 12 November 2017, 08:33:20 »
I would ask this on the Zaf forums, but they are rubbish!
In the Zaf, I'd like to swap the interior bulbs for LED ones which are brighter and I can see better, make things easier getting my 2 little MissT's sorted in the car at night.
Do I have to look for canbus ones? I know on the VW you had to get special kinds or it would trigger warnings.
Yes, I need to go out to the car and look at the various types I need, but sat on sofa now and just thought I'd ask if anyone has done similar.
Was thinking similar to these:
https://www.ebay.co.uk/itm/White-36MM-3-LED-5050-SMD-Festoon-Dome-Car-Light-Interior-Lamp-Bulb-12V-New-P-J/112637463915?fits=Model%3AZafira&epid=4004291214&hash=item1a39b74d6b:g:kEQAAOSw5ZBWJ7NO
Re: Zafira: LED interior lights
« Reply #1 on: 12 November 2017, 08:41:33 »
The interior LED bulbs I've seen are "bright" but give no illumination.  That's why most manufacturers don't fit them ;)
« Reply #2 on: 12 November 2017, 08:49:38 »
I've seen good improvements with LED kitchen lights, bayonet bulbs and other uses like front flood light. Guess I could buy one or two and trial them, for say the boot
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 12 November 2017, 11:14:18 »
Got mine from Halfords. Nice and bright, made a big difference.
Hoof'land storeman.
« Reply #4 on: 12 November 2017, 14:36:36 »
LOL, not quite the same thing ;D
« Reply #5 on: 12 November 2017, 15:15:48 »
True, but it's LED vs others. Prob give them a try  :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 12 November 2017, 17:07:08 »
LEDs make the interior lamps actually fit for purpose: I can now use the map lights to read by, which wasn't possible with the dim yellow glow the incandescent bulbs give. I have them in every lamp including the number plates. Annoyingly, it takes at least 3 different bulbs to do this.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #7 on: 12 November 2017, 17:20:12 »
I think the tech must have moved forward of late. I've just bought a 3x D-cell mag light which is LED, compared to the father's 3 D-cell incandescent from 2016, the LED is far superior. My old 2x AA led torch was actually worse than an incandescent equivalent.
« Reply #8 on: 12 November 2017, 17:53:10 »
I agree, but I think the automotive industry is still in the dark ages...
...and most all retrofits lack a diffuser which is needed for illumination, and the tat that is sold is just using poor quality LEDs anyway
amba
  • Medway towns
    • German V6
« Reply #9 on: 12 November 2017, 18:01:54 »
Led,s in all my interior lights including door puddle lights,on advise from NickW.
What an improvement they make and I can see what is in the boot,on the floor of the car and if needed see whats on my work sheets.
Well worth the effort and cost :y
  • Chatham, Kent
« Reply #10 on: 12 November 2017, 19:37:34 »
'dangle berries'
  • Chatham, Kent
« Reply #11 on: 12 November 2017, 19:52:33 »
It's not of late, just that Maglite's LEDs are hugely out of date. My £30 Remix Ld10 - a single AA torch - outperforms a 4 D cell Maglite. The only reason to carry such a thing is that as a torch it makes a fantastic club.
« Reply #12 on: 12 November 2017, 20:20:34 »
It 'should' work, the interior lights are dimmed on/off so its dependent on what the mosfet driver thinks of the active load
« Reply #13 on: 12 November 2017, 21:06:10 »
Thanks. I did read I would loose the dim feature with LED, but not fussed at that.
Might pop down Halfords during the week with the trade card!
  • Chatham, Kent
« Reply #14 on: 12 November 2017, 21:18:40 »
I bought mine from Ebay for about £1 each; the Omega uses a combination of 36 and 39mm festoon bulbs for the puddle lamps, boot lamp, rear courtesy lamps and number plate lamps. I don't remember what went where as they're fit and forget. The front courtesy lamp and map lights use 501 bulbs like the sidelights; I found these to be a bit more fussy as the ones I was given didn't work. All of the others I've bought since do, and they dim correctly which was a surprise.
