Author Topic: Signum rear light fault part 2.  (Read 3315 times)
« on: 14 November 2017, 12:50:54 »
I've removed the rear light unit and found this. With the ignition on I have checked and there is no power getting to the connection 3rd from the left.
All bulbs look intact. Plastic connector looks as though it has melted.
Looked in the handbook but can't find fuse for rear lights.
Re: Signum rear light fault part 2.
« Reply #1 on: 14 November 2017, 13:02:53 »
Fuses on that are all nearside...
Behind left dash end panel, and in left boot cubby :y
The Vectra C has a system whereby if one of the brake lights fails, it ups the current to a side light bulb in order to maintain a brake light on each side... Possible that this has caused the plug connection to melt due to moisture ingress :-\
Might be fog light position on both sides rather than side lights, but either way, check the bulbs for position and wattage along with contact condition ;)
« Last Edit: 14 November 2017, 13:15:32 by Doctor Gollum »
« Reply #2 on: 14 November 2017, 13:16:47 »
What colour is the wire at the melted contact?
« Reply #3 on: 14 November 2017, 13:21:32 »
Brown..
« Reply #4 on: 14 November 2017, 13:34:43 »
Brake light working rear light is not.I was surprised to find the rear stop/ tail light  work from a single filament
« Reply #5 on: 14 November 2017, 13:36:22 »
Brown..
That's the ground/earth/negative*
Check all the bulbs for voltage/wattage and replace any suspicious ones...
*delete for preference  ::)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 14 November 2017, 14:05:34 »
Canbus varies the voltage to suit :y
other rides
« Reply #7 on: 14 November 2017, 14:36:16 »
Well not actually canbus, the Rear Electrical Centre, when it receives a command for tail lights limits the current through the bulb so it illuminates at a lower wattage, when a brake command is received it allows full current.
In basic terms, the controller has a dimmer function  :y
« Reply #8 on: 14 November 2017, 14:51:57 »
Shame. I have a shit load of the old style stop/tail twin filament bulbs knocking around. ::)
The main problem appears to be the black plastic multi-connector. The slightest movement and I lose the rear lights.
However, as a  highly qualified engineer ::) I have shoved some bacofoil into the said connector for a tighter fit.
Working as it should (for now) :)
« Reply #9 on: 14 November 2017, 15:10:16 »
You can't beat a good old fashioned bodge!  :y
« Reply #10 on: 14 November 2017, 15:36:33 »
During the war the British people had an attitude of 'make do and mend' :)
« Reply #11 on: 14 November 2017, 15:37:13 »
So named after the person who designed the ill fated Tay Bridge
« Reply #12 on: 14 November 2017, 17:31:22 »
As a mere youngster I'll have to take your word for that M'lud.  :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #13 on: 14 November 2017, 17:52:24 »
Bodgers were an important part of the furniture trade around High-Wycombe. They turned things like chair legs, spindles etc by hand on simple lathes. Paid by piecework.
Lincs Robert
« Reply #14 on: 14 November 2017, 18:00:01 »
Didn’t the have pet Badgers, & ate mash?  ;D
I’ll leave now .........
