Author Topic: steering rack or front wheel bearing problem?  (Read 8383 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« on: 28 November 2017, 19:18:33 »
Getting a nasty wobble/rumble when I take a left hand corner. Jacked the driver front and there is movement 3-9 o'clock. This isn't happening on the passenger side. Am I right in thinking that as left and right steering components are connected that this rules out steering rack problems?
On this basis I was looking at the guide for replacing the wheel bearing. However, the guide appears to be missing the part about how to actually remove the bearing. It goes from removing the caliper straight to putting the new part on.
Additionally, when I search for replacement front wheel bearing for the car I get results showing just the bearing and others showing the hub assembly. Is this because if you have the tools to remove the bearing the hub is reusable?  ???
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: steering rack or front wheel bearing problem?
« Reply #1 on: 28 November 2017, 19:21:39 »
Omega front wheel bearings aren't a serviceable part. You buy a new hub, unbolt the old one and replace it with the your new one.
« Reply #2 on: 28 November 2017, 19:24:46 »
And FYI, the Omega doesn't have a rack.
Ideally, jack up the suspected corner, you can normally feel play in a knackered wheel bearing, or can feel its roughness if you slowly rotate it.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 28 November 2017, 19:45:04 »
Piece of piss to change. Only issue you "may" run in to is if the inner race has become one with the stub axle. I'm sure someone (Entwood maybe?) had this happen and you'll need a small cut off wheel to remove it.
Hopefully that doesn't happen though and it'll slide off and new one will slide on 👍
RIP Paul Lovejoy
berserkerboy
« Reply #4 on: 28 November 2017, 19:55:17 »
Thanks folks.
So once I have the big undone the assembly should just pull off?
berserkerboy
« Reply #5 on: 28 November 2017, 19:56:33 »
What torque should the big nut be done up to on reassembly?
« Reply #7 on: 28 November 2017, 20:26:47 »
That do :y
And 390lb/ftto tighten  ;)
berserkerboy
« Reply #8 on: 30 November 2017, 19:56:30 »
Am taking a punt that the problem is the bearing. Wishbones where done about 6K ago and no movement is apparent at the ball joint. Although I can swivel the steering balljoints around by hand there is no apparent play or knocking coming from them. The bearing doesn't feel too bad on rotation, no grittyness, but there is definately a bit of noise when I spin it around. As Webby the Bear suggested, the bearing has come off easily once I got a breaker bar and a long piece of pipe on the end. New bearing has cost me £26.30 delivered and I await its' arrival.
The brake dust cover behind it has crumbled to dust itself. Anyone know where I could get a replacement? :-\
Webby the Bear
  • Northampton
« Reply #9 on: 30 November 2017, 20:18:03 »
I'd see if there's one in a scrappy or eBay or a wanted ad 👍
RIP Paul Lovejoy
« Reply #10 on: 30 November 2017, 20:22:10 »
Just an idea ... it's what I do so I pass it on ... I don't have a torque wrench big enough to go to do 320 NM, so I follow the instructions in the guide
http://www.omegaowners.com/forum/index.php?topic=90544.0
but at post #5 I fully fit the wheel and do all the wheel bolts up correctly, I then tighten the hub bolt as far as I can with my torque wrench ... 270 NM. I then drive the car to my local garage and for £2 in the charity box they use their bloody big torque wrench and tighten it properly. I then drive home, remove the wheel and fit the hub cover, then refit the wheel.
It's a bit of a faff but easier/cheaper than buying a torque wrench that goes to 320 NM !!
  • Chatham, Kent
« Reply #11 on: 30 November 2017, 20:56:48 »
Why bother? Cut the crusty bits off with some snips and do something important.
berserkerboy
« Reply #12 on: 30 November 2017, 21:40:22 »
Well 320NM is about 32kg at 1 metre or 16kg at 2metres. With the breaker bar and metal pole I can get 2m away. So I just need to put 16kg of weight at the end. I reckon so long as I have at least 320NM it'll be okay.  8)
berserkerboy
« Reply #13 on: 30 November 2017, 21:43:07 »
Okay :y
« Reply #14 on: 01 December 2017, 09:22:05 »
Before randomly changing the Wheel Bearing (which would likely be noisy as well as having play) get a young assistant to put their foot on the brake when you rock the wheel... If the play remains then it’s not the bearing but one of the numerous ball joints in the steering assembly, which is far more likely.   ;)
Edit: Just read that it is a bit rough/noisy so my be the case it needs doing anyway but I’d still be doing the test with the brake applied. All that said, it could easily be more than one component causing the issue.  ::)
« Last Edit: 01 December 2017, 09:24:13 by Lazydocker »
