Author Topic: Mondeo TDCi Diesel Knock  (Read 3856 times)
« on: 01 December 2017, 21:13:58 »
Evening everyone,
Wondered if anyone had any thoughts on this.
I have a 2010 Mondeo, 2.0 TDCi 6 speed, which I've covered 10k in, over the last year. Fantastic car, rapid, 55mpg, handles well. Not had a single problem. 79,000 miles, lots of history, and home serviced by me including 3k oil and filter changes.
Tonight, I went to go to Argos to collect something. Immediately upon pulling off the drive (cold engine) there was a constant, almighty diesel knock, at anything above idle. This lasted for the ten mile journey, although wasn't quite as bad by the time I arrived.
I then went to Halfords, and put in almost a litre of wynnes type extreme clean treatment. The tank was just dropping onto the red at this point. I then took a more scenic drive home, and gave it a proper Italian tuneup.
Upon arriving at home it sounded almost normal. I guess the test will be, what it does on the next cold start, but, any ideas?
I know the earlier mondeo's were plagued with injector issues, but having done some reading, it appears that the engine in my car is supposed to be a bulletproof Peugeot diesel.
No noticeable power loss, no smoke, no EML, running fine. Just noisy. It's definitely diesel knock, and the oil level is fine.
Any further ideas please chaps?
  • Auckland
    • Mazda MPV
Re: Mondeo TDCi Diesel Knock
« Reply #1 on: 01 December 2017, 22:37:03 »
I don't have any model specific knowledge but could it be a rattle from something else?
Dual Mass Flywheel (DMF)?
or maybe the alternator pulley? (SWMBO's Galaxy diesel suddenly started running really rough last year - you could feel each compression/firing stroke through the steering when parking. Turned out to be the over-run clutch in the alternator pulley. A simple fix once I worked what was wrong.)
« Reply #2 on: 02 December 2017, 02:08:12 »
Flywheel would be my first thought too :-\
« Reply #3 on: 02 December 2017, 03:38:08 »
Also crossed my mind, and as always I'm happy to be proven wrong...
 but... it's a profound diesel knock...  I recognise the sound of old from previous diesels, including automatics. Definitely a diesel knock, rather than anything mechanical, so to speak...  :y
I've heard loads of flywheels let go, and start to get worn, in works cars... this noise is a diesel injector  :-\
« Reply #4 on: 02 December 2017, 08:20:24 »
Duff injector should be readily identified at the fuel rail... touch the pipe to each injector and the duff one will feel very different.
Flywheel can also show up as a rhythmic thumping.
When cold, do you press the clutch before cranking?
« Reply #5 on: 02 December 2017, 11:16:18 »
Cheers Al :y
I sure do press the clutch when starting. Old habit from the days of my 1993 405 diesel which wasn’t keen on starting in winter!
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #6 on: 02 December 2017, 11:37:38 »
Does pressing the clutch on start help preserve the DMF, as opposed to just starting in neutral with the clutch out? If so I've learned something new today!
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 02 December 2017, 16:48:02 »
I used some free software called FORSCAN to recode injectors on a TDCI I had, handy for fitting new or used ones
« Reply #8 on: 02 December 2017, 16:58:57 »
Interestingly, it was absolutely fine when I Did a 20 mile run today....
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #9 on: 02 December 2017, 18:55:46 »
My son has a very nice 51 or 52 plate TDCI ex-plod Mondeo. It has been standing unused for at least 6 years in his garage. (Don't ask me :-X). IIRC it cost about £400 for Ford to code the injectors back in the day. Fortunately it was never required. :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #10 on: 02 December 2017, 21:14:25 »
I use ford scan on daily bases
Great tool
serek
  • huntingdon
    • 3.2 mv6
« Reply #11 on: 02 December 2017, 21:16:25 »
On 2.0 tdci siemens injectors no coding required
Only correcting
