Author Topic: spanner light  (Read 2629 times)
jacko
  • london
    • vauxhall omega 2.2
spanner light
« on: 13 December 2017, 09:44:28 »
hi guys,
I will explain the best I can,
yesterday morning - 3 temp car started then instantly cut out, tried to start again wasn't even attempting to fire, after sever attempts over a half hour period it started but was only seemingly running on 3 cylinders on tick over was ok at revs, spanner light was on then after a short drive spanner light went out main engine management light came on, changed coil pack as I had a spare all running smooth again after a test run main engine management light has gone out but spanner light back on , any ideas chaps  ::) ps this is a 2.2 petrol by the way.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: spanner light
« Reply #1 on: 13 December 2017, 13:22:45 »
When my spanner light came on it was faulty cam sensor.Have you got any codes?
Re: spanner light
« Reply #2 on: 13 December 2017, 13:57:06 »
Following a breather/throttle clean, camcover and new plugs, the light on mine has stayed well and truly off 8)
Still occasionally struggles to start though, so a crank sensor is probably somewhere in its future ::)
Re: spanner light
« Reply #3 on: 13 December 2017, 14:08:52 »
I'd get the codes read, sounds like cam sensor to me. You will need a code reader to clear the spanner fault  :y
Was there any water/oil in the plugs?
jacko
  • london
Re: spanner light
« Reply #4 on: 13 December 2017, 17:18:54 »
no there was no water in the plugs have had head gasket done recently. and had cam sencor done 2k ago new plugs ect. after i replaced the coil pack it is running fine i gues my mail question was will the spanner light not clear itsself as the engine manament one did?  :y
Re: spanner light
« Reply #5 on: 13 December 2017, 17:52:28 »
No, you need the codes cleared.
Also worth cleaning throttle body, make sure that is nice and clean. Known them to get stuck randomly, then free up.
Re: spanner light
« Reply #6 on: 13 December 2017, 19:04:18 »
Without codes, anything is a guess.
