Pages: 1 2 [3]  All   Go Down
Author Topic: which three year old auto boxes are the best.  (Read 10434 times)
Re: which three year old auto boxes are the best.
« Reply #30 on: 03 January 2018, 19:30:05 »
ZF 8 speed auto fitted to my Jag
I feel ratio inadequate, with just a measly 6...
I look up to Dr Opti with his 8 but look down on you with your 6  ;D
I know my place
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #31 on: 03 January 2018, 20:23:39 »
Three would do with the torque you have,Vauxhall used to make do with just two on the old powerglide in Cresta's :y
other rides
« Reply #32 on: 03 January 2018, 20:31:29 »
Even my poxy astra has six.  ;D
« Reply #33 on: 03 January 2018, 20:36:00 »
8th gear on my car works out at roughly 50 MPH for each 1000 RPM. About 1400 RPM at 70 MPH.
This is tall gearing for a petrol car probably to help economy and Co2 figures. Both 7th and 8th gear offer SFA in meaningful acceleration.
The USS Enterprise  probably uses shorter gearing.
« Reply #34 on: 03 January 2018, 20:38:27 »
I believe Jeep has nine and Lexus has ten.......which is probably overkill
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #35 on: 03 January 2018, 20:56:45 »
I believe there are quite a few cars either current or due out soon that have ten speed boxes,iirc the Lotus Carlton/Omega with it's six speed manual pulled 44mph per 1,000revs in top,so not so far off your Jag Opti.
« Reply #36 on: 03 January 2018, 21:33:57 »
Yep...exactly right, Mr Baza.
 Sixth was more of an overdrive as the LC reached top speed (176 MPH) in 5th.
« Reply #37 on: 03 January 2018, 21:35:08 »
I know my place
;D ;D  ;D ;D
« Reply #38 on: 04 January 2018, 09:00:16 »
I saw a yank tank advertised recently with a two-speed powerglide  ::) Given the size of engine though, I assume that's one gear for burnouts and one gear for everything else ;D
« Reply #39 on: 04 January 2018, 10:48:33 »
20 years ago I drove around Australia in an old Ford Cortina (Yolanda!) with a 3 speed auto box!  :y
Unfortunately 2nd gear was AWOL. Which wasn't too much of a problem as Australia is mostly quite flat, so I used to boot it in 1st and then it'd slide into 3rd, chug a bit, then catch up with itself and off I'd go!  ;D
Heading north out of Adelaide is quite hilly and I had to stick it in 1st and crawl up the steep hills, which was quite interesting with the Road Trains thundering past.  :o  :)
Pages: 1 2 [3]  All   Go Up
