BMW ABS ECU Goosed!
Started by Sir Tigger KC, 08 January 2018, 23:36:44
Mr Gav
Quote from: iansoutham on 09 January 2018, 19:53:30
Send me your reg and Ibwill see what I can find out for you.
As a BMW Parts Manager, I might be able to help.
I bet you don`t get many requests for indicator bulbs  ;D
iansoutham
Loads actually.
Mainly because they were not using it when they pulled out in front of someone and smashed it....
Mr Gav
Quote from: iansoutham on 10 January 2018, 10:55:58
Loads actually.
;D ;D ;D
moggy
Hi guys,a little off topic.But a friend of mine took his bmw to the dealers in Newcastle.They did a diagnostic test as he was getting a low brake pad warning.They said he needs a new disc and pads on one side,£580 is that correct sounds a bit over the top to me.Dean :o
You know that BMW stands for Budget Much Wonga?
TD
Quote from: Nick W on 10 January 2018, 16:40:39
I thought it meant something else.....along the lines of a coloured guys plonker  ;)
Quote from: moggy on 10 January 2018, 16:08:54
:o
Run. Just run.
ronnyd
Quote from: TD on 10 January 2018, 17:35:48
Are we allowed to say that now?  :-\ ;)
Quote from: ronnyd on 10 January 2018, 17:55:54
I've got another one if you're worried. It's still a bit rude, though (obviously). ;)
henryd
If they plan to change one side only they want shooting,burying,digging up and shooting again,where's TB's cull list  ::)
other rides
I work with a BMW nutter...
He was quoted about £400 pads, supply only with discount... so he bought Pagid...
... For the same price as BMW sell them via their ebay store ::)
He wasn't impressed when I told him... even less so when the Pagid pads are still squeaking a thousand miles later ;D
moggy
Quote from: Doctor Gollum on 10 January 2018, 20:09:23
That is shocking DG,so my friends best bet is to buy from a local factors and have them fitted by a local garage.Any recommendations as to make of pads Dean.
Shackeng
Are BMW brakes more difficult to work on? Disc brakes and pads generally are so simple, they are difficult to f**k up for even the lamest numpty. I blessed the day when drum brakes disappeared on my cars. :y
Quote from: Shackeng on 11 January 2018, 10:25:55
Agreed. But you know what they say about making something idiot-proof? ;)
Had a flashback to drum brakes recently when I had to overhaul my handbrake. ::)
No.  I replaced the front discs and pads on mine last year and it was no harder than any other vehicle.  :y
I found a set of Unipart front discs that were clearance on ebay for £19 and I forget where the pads came from but it would have been cheap ebay or ECP.  :y
I press the pedal and the car stops. Job jobbed!  :y  I await my ritual slagging!  ;D
