How did Serek do it?
Started by Bigron, 09 January 2018, 16:12:44
GastronomicKleptomaniac
Quote from: TheBoy on 12 January 2018, 16:53:10
Quote from: Bigron on 11 January 2018, 20:24:11
Yep, me too, when it was on special - I have 10 litres, hence my use of it!
You would advise that I dump it, then?
Ron.
You're lucky you only bought 10l of the shite. I was an idiot and bought a load  :-[
I'm guessing this can't go down the drain, so how do I get rid?
Down the toilet, give your morning doings an automotive scent...
Migv6 le Frog Fan
Tip it in neat, or give it to me.  ;D
Use it to flush your plumbing. :y
biggriffin
I use halfords, about £2.50 with trade card.
Hoof'land storeman.
Quote from: biggriffin on 12 January 2018, 19:59:14
I use the yellow stuff (-20c maybe?) from Halfords normally, I think its now just over £3.  Normally in winter mixed 50:50, unless its looking to be proper cold like a few years back.
The Triple QX shite, despite being labelled as concentrated, I think is premixed.  No clues on label, just how to mix based on season, rather than what sort of temps each mix will give you...   ...and they seemed to be a strong ratio to me, hence just using neat.
Bugger me, its gone up to £5.63 :o
http://www.halfords.com/motoring/engine-oils-fluids/screenwash-de-icer/halfords--20-concentrated-screenwash-5l-citrus
Need to see what Costco are offering (often the Holts stuff, which I don't rate too highly, seem to get white chalky smears with it...  ...though am in med/hard water area)
biggriffin
Quote from: TheBoy on 13 January 2018, 09:50:26
Just mix it to 50%, still works well, in the arctic conditions we get here in Blighty.
Hoof'land storeman.
Quote from: biggriffin on 13 January 2018, 14:17:20
Yeah, I do rate it as reasonable good :y, shame its got ridiculously expensive :(
Viral_Jim
I'll be using toolstation own brand for a while
As it was free  ;D
I use Halfords Blackcurrant and mix it roughly 25% screenwash / 75% water, so I end up with about 20 ltrs of screen wash which lasts for ages.  Not had a problem yet!  :y
TD
I must be lucky then, coz when I take the Mondeo in for a service, the garage tops up the screenwash, which lasts until the next service, no idea what they use, but it works ok  :)
Quote from: TD on 13 January 2018, 18:08:21
Not lucky, just not making mountains out of molehills. There's nothing complicated about choosing using screenwash.
Quote from: Nick W on 13 January 2018, 19:39:13
So, I take your advice, and buy a load of "whatever is available and cheap" concentrate, use it neat, and as soon as we get (just about) sub zero temps, it freezes.
And another member using the same has had his filter block again.
Clearly, screenwashes vary from quite good to utter shite.
Quote from: TheBoy on 13 January 2018, 19:45:13
It's fickin water, with a bit of soap and antifreeze in it.  :P
Oh....and apple perfume in mine. Nice  ;D
Quote from: STEMO on 13 January 2018, 19:55:57
I think in the cash of that shite I bought a load of its water with a small amount of dye in it to make it look like screenwash ;D
No cleaning agent, and clearly no antifreeze agent.  And if it allows that white slime to grow, no antibacterial agent in it either.
