Author Topic: I have issues with a Citroen Xsara Picasso...  (Read 5528 times)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« on: 12 January 2018, 18:24:12 »
I have an old Picasso, which, suddenly started having issues with its indicators back in October...
Whenever I turn the ignition on, the headlights come on (even though it doesn't have DRL's) and when the headlights are in the off position, the indicator will flash maybe a couple of times then stop.  If the lights are on, then they work as they should.
In order to get the indicators off (Com 2000 unit) the steering wheel and airbag needs to be removed and a general ballache of a job is necessary and also a costly replacement (more than the value of the car)... Anyone got any ideas?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: I have issues with a Citroen Xsara Picasso...
« Reply #1 on: 12 January 2018, 18:47:37 »
Can't resist,,,, It's French.
A totally helpful post I know.
Hoof'land storeman.
« Reply #2 on: 12 January 2018, 18:58:32 »
A ex colleague of mine had one new, and it had 3 dashboards IIRC within the first year, due to various different electrical faults, including headlight issues.
Citroen swapped the car in the end, for a demonstrator, due to the non stop problems.
It does seem, once you start getting electrical issues with them, might be worth getting shot of quickly.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #3 on: 12 January 2018, 19:52:06 »
+1  ;D ;D ;D
2boxerdogs
« Reply #4 on: 13 January 2018, 08:20:18 »
Sounds like it's time to get rid.
T.m.f
    • 4wd
« Reply #5 on: 14 January 2018, 03:44:02 »
Buy linx 3 (i think its called) which has the correct diagnostic software ,could be the bsi module needs replacing.
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
« Reply #6 on: 14 January 2018, 08:36:44 »
Pity you’re not closer... I have the PSA Diagnostic Software.
But it sounds like the electrical gremlins are trying to escape, which for most things French means it’s time to call it quits ::)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 14 January 2018, 10:17:06 »
I recovered several of those with smoky underdash electrics. Everyone had previously been suffering from intermittent indicator faults.
« Reply #8 on: 14 January 2018, 10:19:28 »
Yep, ISTR they suffer from the fuseboxes getting a bit melty. :o
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 14 January 2018, 12:58:00 »
If you do end up replacing the indicator stalk assembly with the airbag squib gubbins it's really not that bad though looks daunting.
Negative battery cable off for a few minutes. Take off the plastic cowl top and bottom (probably held on with a couple of torx or phillips screws. Pop the airbag off (usually a hole in the back to put a pick through to release the airbag. Disconnect electrical connectors. Steering wheel bolt out. Wheel off (don't smack yourself in the face with it). Then if memory serves there's a 10mm that secures a metal band at the back and that whole unit should slide off. There may also be a couple of other electrical connections I've forgot about.
It's been a while since I've done one so that's from memory but I remember thinking it was actually a nice job to do. Hth :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #10 on: 14 January 2018, 13:00:08 »
Aaaaaaaaand thinking about it I think I MAY have one if needed. Pm if needed  :y
RIP Paul Lovejoy
« Reply #11 on: 14 January 2018, 13:00:33 »
Agree, except......if you own a Citroen Xsara, you really should let the steering wheel smack you in the face.  :)
Webby the Bear
  • Northampton
« Reply #12 on: 14 January 2018, 13:03:59 »
 ;D no comment
RIP Paul Lovejoy
« Reply #13 on: 14 January 2018, 13:15:56 »
I assume that's a technical term .....  ;D
